headman long tube headers
Old Oct 2, 2006 | 11:00 PM
stevesz-28's Avatar
Car: 1985 Camaro Z-28
Engine: 305 (lg4)
Transmission: 700r4 with transgo shift kit
hey i just was about to buy some headman long tube headers from summit and i was wondering how hard it would b to install them? can i do it with the motor/trans in the car and do u have to jack the moter up?
Old Oct 2, 2006 | 11:04 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
jack the car up HIGH and put them in from underneath, you also have to pull the starter and you might have to cut a little out of the kmember depending on your motor mount height as they sag over the years
Old Oct 2, 2006 | 11:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
On my 84, the driver side went in from the bottom with the car maybe 2' in the air. The passenger side went in from the top with the starter removed (no A/C). Both sides required substantial cutting of the A arm mounts on the K member to clear with brand new urethane motor mounts.
Old Oct 3, 2006 | 07:39 PM
stevesz-28's Avatar
Engine: 305 (lg4)
headman headers
well i was wondering if i undid the motor mount and jacked the motor up if they would slide in from the top or slide in from the bottom?
Old Oct 3, 2006 | 08:03 PM
RedLava's Avatar
Car: 86 z28
I put both of mine in from the bottom. I also need to get the motor jacked up extremely high, as in as high as it would go. The passenger side just slid in and bolted right up. The drivers side needed a little dent from a hammer in one pipe and grinding of a a small amount of corn of the a arm. I also need to get the motor jacked up extremely high.
Old Oct 3, 2006 | 08:06 PM
stevesz-28's Avatar
Engine: 305 (lg4)
other than that thet worked fine what made you have to dent one side?
and what did u have to grind
Old Oct 3, 2006 | 08:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I didn't have to raise the engine on mine. Both of them went in as described above with the engine bolted in.
Old Oct 3, 2006 | 08:16 PM
stevesz-28's Avatar
Engine: 305 (lg4)
well y do u have to dent one of the pipes?
what is in the way of the pipe
Old Oct 3, 2006 | 08:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The usual place that most people have problems is around the driver side A arm mount. I also had clearance problems on the passenger side. I notched the A arm mounts on both sides to clear mine.
Old Oct 3, 2006 | 09:57 PM
RedLava's Avatar
Car: 86 z28
the cross member that goes under the motor was in the way. so i figured a small dent was better then cutting into the cross member.
morrow
Jan 13, 2024 12:29 PM
italiano67
Dec 11, 2016 09:21 AM
92projectcamaro
Jan 18, 2016 08:00 AM
formula_novice
Sep 5, 2015 03:58 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
