critque my setup
Old Oct 9, 2006 | 06:06 PM
85irocz28's Avatar
Car: 1985 Iroc Z
Engine: 383 carbed
Transmission: Th 400 tci super street
Axle/Gears: 3:42 9 Bolt
critque my setup
ok guys i have hedman longtubes.. now i dont care about being legal so here are my thoughts. 3 inch piping. 2 cut outs right after the headers. summit h pipe then dynomax bullets. all before the axle. wat do u think?
Old Oct 9, 2006 | 07:05 PM
CrazyBear's Avatar
Car: 1987 Camaro,'89 firebird
Engine: 305 quadjet, 305 tbi
Axle/Gears: 2.73. 3.2xs
I prefer x-pipes over h-pipes. Also im not into the super noisy stuff so the bullets have to go and something more muffled like hooker aerochambers should go on. What would be cool is if you had pipes comeing out the sides like two on each side.
Otherwise i guess it'll be fine.
Old Oct 9, 2006 | 07:25 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
It will be very loud. I wouldn't bother with the cut out's either, the Dynomax bullets aren't what I would call restrictive.
Old Oct 10, 2006 | 06:03 PM
85irocz28's Avatar
Car: 1985 Iroc Z
Engine: 383 carbed
would a xpipe be harder to fit.. i would like the exhaust to go as smoothly as possible cause im doin it.. ill also have SFC. an aftermarket Tq arm to get in the way of stuff
Old Oct 10, 2006 | 08:11 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
big block or small block?
Old Oct 10, 2006 | 08:57 PM
85irocz28's Avatar
Car: 1985 Iroc Z
Engine: 383 carbed
smallblock 383 480hp crank hp not brokenin.. built for n20
Old Oct 11, 2006 | 04:12 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
go with that setup without the cut outs and im sure you'll be very happy. im sure the cut outs arent neccesary with bullets because 8 and 7 sec cars run similar setups with bullets.
Old Oct 12, 2006 | 02:51 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Thats the set up I am running and if you have a pretty big cam, which I assume you do, then don't plan on talking to people in or outside your car. It is defeningly loud. I have hooker 2210s, dual 3" and a set of dynomax bullets and dumps. Loudest car I have ever herd on the street, EASY. Too loud. I am making another exhaust this winter. My motor is supposed to make around 510HP. I am going to go with dual 2.5" pipes and an h or x, not sure yet. Then have them come togeather behind the back seats if possible and go over the axle and dump back there someplace. Oh also slap on some spintechs or something once the pipes are back there. I have to get these pipes off.
I too am running an aftermarket TQ arm.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
