Welding on ceramic coating
Old Oct 24, 2006 | 05:37 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Transmission: Built 700r4
Axle/Gears: 3.73's w/ stock axles
I have a chance to pick up a set of headers and a y-pipe that are ceramic coated. The only problem is that the y-pipe was cut in two places and I want to know if welding them back together would harm the coating. I've never personally seen the coating up close, so should the weld areas be grinded or preped before welding?
Thanks Toby
Old Oct 24, 2006 | 07:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The coating will have to be removed before welding.
Old Oct 24, 2006 | 07:13 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
Just on the affected areas, right? The rest should be alright? It shouldn't cause the rest of the coating to crack should it?
Can I just make the two girth welds after the coating in that area is grinded back a half inch or so and be done with it or is it not worth it.
Old Oct 24, 2006 | 07:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Just in the areas you're going to weld should be fine.
Old Oct 24, 2006 | 07:21 PM
systalis's Avatar
Car: 92 RS
Engine: Built 355
K, thanks! A 4" grinder should do for removal right?
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
no green
Jan 9, 2016 09:22 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
meeklay812
Oct 1, 2015 03:46 PM
