Hooker super competion
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
Any one use these? http://store.summitracing.com/partde...5&autoview=sku
Just wanted to know how the installation went. Because if they fit good I'll juts fab up some exhaust to fit in my y-pipe.
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
I would go with someting that has a primary size of 1 5/8. I had a set of heddmans that were that size and that fit great. I dont think I paid that much for them. If it has to be the Hooker go with the 2210's.
Transmission: 4L80E/4L80E
Those are the ones that follow the stock routing. Really weird ones. But, with the small primaries, don't make a lot of sense (although they'd probably work will on a slightly warmed-up 305, or a low-RPM torque 350).
Car: 1987 IROC
Engine: 350 Gm H.O
Yeah I here the 2210's are really good but I don't really want to spend near $700 with shipping Since I'm getting my car painted soon. Unless there that much better than cheaper ones. I have no preferance on what company it is. I just want a reasonable set of long tubes that fit on my 305. Any other suggestions will be helpful.
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
I have heard that up to 400hp you can use 1-5/8 primarys. 450+hp and you should go with 1-3/4 primarys. This is for long tubes
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
go to wwwjegs.com and part number 520-2210 there only $449.99, not cheap by all means but better then 700
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
the price went up 449.00. I think they are seeing a decline in these sales and raised the price to compensate for it. Holley likes to control their own pricing.
Car: 1987 IROC
Engine: 350 Gm H.O
$449 isn't to bad. Thats only 50 more than the TES shorty's from Edelbrock and I would rather have long tubes any day. Just one more set of Lt's I found. http://store.summitracing.com/partde...5&autoview=sku
Do these seem any good?
A lot of members have used those (or the uncoated version).
Car: 1987 IROC
Engine: 350 Gm H.O
Five7kid, do you know if anything gets in the way of these Lt's(refering to the hedman street headers) when installing them? It doesn't matter that much because anything can be cut and removed. I just wanted to know before I would install them.
Thanks for the info so far.
I haven't installed them, personally. From what I've gathered, they are the best fitting long-tubes available. Any clearancing would be minor. The problem comes with the exhaust that goes after it. Search this forum for posts by mw66nova, he used those headers and built exhaust for them that probably provides the best ground clearance you can get (without refabricating the transmission crossmember). This thread https://www.thirdgen.org/forums/exha...el-bent-y.html shows both a y'd system and dual system.
This assumes you don't have emissions issues to deal with.
Im running the hooker 2138's right now
Nothing but good things to say bout em
They install tight and ground clearance is better than stock
The summit pic is off, they look like this... definately the wierdest header ive ever seen
Car: 1987 IROC
Engine: 350 Gm H.O
Thanks everybody for all the information. I have came to a conclusion that I am going to get the hedman street headers. FIVE7kid, those pictures helped alot. I cant wait to get them and install them. Thanks again everybody.
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Those are really pretty cool man. I've never seen those before. I am suprised more people dont use them. You can run true duals with those and follow the stock routing pretty easily which would promote much better ground clearance. I would have used those had I have known about them, but they wouldnt fit with the corvette pan I am using though. Anyway, those are really neat, I should have thought of that.....
But, as stated, they are 1-1/2" primaries. Pretty small for anything more than a stock 305 or low-RPM 350.
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Axle/Gears: 9 bolt 4.11
If you want ceramic coated long tubes with a 1-3/4 primary check these out.... Doug's for $499
http://www.jegs.com/webapp/wcs/store...9637_-1_528847
Car: 86 IROC
Engine: 383
Oh Thanks for cleaning that up for me again. I just realized they were small primaries. Why did they ruin a cool design by making them unusable with small tubes? That's stupid. 1.5" is too small for even a 305.
Read the exhaust theopry stickies up top of the page
Hotrodboba400
Dec 10, 2019 07:07 PM
no green
Jan 9, 2016 09:22 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
