Thoughts on how to ovalize exhaust pipe
Old Jan 23, 2007 | 08:17 PM
Jon614z28's Avatar
Car: 1992 Z28 Aniv. Edition
Engine: 5.3 L33 Turbo
Transmission: Tremec T56
Axle/Gears: 3.27 Borg 9Bolt
In a quest to keep precious ground clearence, im going to attempt to ovalize some pipe, i could buy it from DR.Gas but i figure its worth a try, so, my thought was to fill the pipe with a 2x4 ripped down to fit inside the pipe tight against the sides at 1.25" height and rolling it with my truck or a roller from work in hope to have a nice ovalized pipe that is only 1.25" tall and as wide as what is left over from a 2.5" pipe. The only object is to get the pipe so it doesnt pinch on the ends. Im all ears for suggestions! Thanks
Old Jan 23, 2007 | 09:12 PM
chevycamaro91's Avatar
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
u could put it in a vice and just crush it as far u want, might take a little time though. just my
Old Jan 23, 2007 | 09:19 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
or you could call boyce industries and buy the pipe as they are much cheaper than dr gas and spintech.
Old Jan 24, 2007 | 01:50 PM
Jon614z28's Avatar
I never heard of them Thanks, ill do some research
Old Jan 24, 2007 | 09:07 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I have done it in the past with the press brake at work and the tube filled full of sand. It came out very nice. The other thing I have done was to cut apart a u-bend in the middle and add in a filler peice. That worked out really well for a job that I did.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
formula_novice
Sep 5, 2015 03:58 AM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
