new exhuast design!
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
new exhuast design!
i just thought of a cool exhaust setup and made a crappy paint illustration. i would need 2 round dynomax ultrflows, 3"in/out (http://store.summitracing.com/partde...5&autoview=sku)
i want the mufflers to be tucked up as high as possible so they are above the bottom of the bumper so a couple of turndowns off the muff will finish it off.
how does that sound to you guys? is it doable? do you think it will sound more like true duals with two muffs? and i have heard that exhaust sytems perform best with the mufflers closest to the exit.
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
The only problem I see with 6" round mufflers is that the tips wont be lined centered correctly - one will be closer to the center of the car then the other because of the way the spare tire and hatch area wells are positioned. I don't think this will matter much in your setup because you will be using turn downs which will probably be hidden.
As far as sound - It wont sound like duals but will probably sound simalar to the L98 corvette exhaust sytems which are y'd from the headers into a single pipe then y'd under the axle to the two mufflers which sit in the same location you are planing.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Doesnt hurt to try, if you dont like it you can allways change it up, I think it would be worth the attempt, as said above, measure twice cut(order) once...
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
lol yea they are too long, i drew that setup when i was like 14 lol and it didnt really work out, mufflers to fit would have to be 13-14 inches or less i believe
Car: 1983 trans am
well i originaly wanted to use borla ovals, but i thought they were too wide to tuck up at 9". i could also use a couple round magnaflows. also the dynatech ovals look good too at 14"long by 7"wide and 4 1/2"tall.
i just want it to sound different than the same old catbacks everybody bolts on. and i planned on fabbin this up my self so i was wondering if i can buy a mandrel bent intermediate pipe to start with. then a couple of j bends and y and i should be able to weld her up.
- i havent had a chance to go measure because my car is sittin in a foot of snow under a cover.
I don't think those round Dynomax ultra-flo's are going to be too long. The case on those mufflers is only 16" long. This guy used the flowmaster hushpower mufflers in that location which have a 18" long body.
http://www.knightfoundation.net/foru...?p=57976#57976
Car: 1983 trans am
i believe the case is 21", that is all ive seen at summit.
Engine: L98 350
Transmission: 700r-4
i made a set up like what you drew up top, but where the cut out is i put a single chamber flowmaster, and just split the pipes after the rear axle and sent them out. i have a video if you would like to hear it.
Car: 1983 trans am
i see in my new jegs that they come in 16" so i will probably go that route. will this be quieter than one oval ultraflow with a dump in the stock location?
Car: 1989 TRANS AM GTA
Engine: 355 L98
Axle/Gears: BW 3.27
Engine: L98 350
im not sure how to upload a movie to this site but i have the movie on myspace.
http://vids.myspace.com/index.cfm?fu...oid=1911126930
if this doesnt work ill try another way
i checked it and it seems like the vid worked
Engine: L98 350
the vid does a poor job of showing
alot of the bass cant be recorded. the single chamber made the car sounds much deeper.
ehh i just listened to it again and it sounds about right :P
alot of the bass cant be recorded. the single chamber made the car sounds much deeper.ehh i just listened to it again and it sounds about right :P
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
being that the design is parallel rather then in series it would actually lower restriction vs only using a single muffler
Z28/ZR1
Oct 23, 2015 01:04 PM
dimented24x7
Sep 6, 2015 03:51 PM
