oil switch too close to headers!
Old Mar 12, 2007 | 02:04 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
how did you guys put headers on when they hit the oil switch? do they make an after market one that is smaller,oil switch i mean? don't it have something to do with the fuel pumps as well?
Old Mar 12, 2007 | 02:15 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
You must mean the oil pressure sending unit? I took mine out to install my headers, then re-installed it after I was done. It clears the hooker 2210's well.
You could take it out and plug the hole and have the sending unit on the back china wall of the block?
Old Mar 13, 2007 | 04:12 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
yes ,thats what i meant ,i'll try it today.thanks.
Old Mar 15, 2007 | 05:14 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
the only thing on the back of my block by the distributor is this square thing sticking up ,and i dont know if it even comes out.a 5/16 wrench seems to fit it though. i didnt want to risk messing something up by trying to take it out.
Old Mar 15, 2007 | 05:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The square thing sticking up is probably a pipe plug in the oil port.
Old Mar 15, 2007 | 05:42 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
pipe plug yes, it is
as for the oil switch down by the oil filter if its too close to the headers and you stil have the ECM in your car and have to keep the switch then you can go to the plumbing store and get a shorter length 1/4" pipe off the shelf or from a drawer so that the switch will sit closer to the block
dirt cheap fix
i just removed the pipe plugged the one on this 305 today that i got for my 82 sinc ei have no ECm or harness anymore and swapped on a non-EST carb and HEI and will be running headers if they fit good enough
good luck
89GTAOz
May 16, 2020 09:31 AM
Street Lethal
Apr 30, 2019 12:14 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
355sbcTPI
Aug 19, 2015 04:38 PM
