How Hard is it?
Old Mar 26, 2007 | 03:06 PM
Shawn Ryback's Avatar
Car: Firebird 1989
Engine: 2.8 Litre
Transmission: Automatic
How Hard is it?
How hard is it to replace the muffler in a firebird and when is it time to do so? It is a dual exhaust muffler so I don't really know this part of the car.
and how do you do it are any special tools needed?
Thank Auto Brothers
Old Mar 26, 2007 | 03:16 PM
Camaro355Z28's Avatar
Car: '86 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: standard 3.23
Re: How Hard is it?
Usually when there are holes in the muffler is it time to replace it, pretty common sence. If you are replacing just the muffler there are a couple options, you can either make the muffler slip fit over the existing pipes and clamp them with clamps or have them welded together which is usually the best way but if you have no access to a welder then clamps would be fine. Usually when the muffler goes bad though the pipes are bad themselves or are on the verge so I would just recommend getting a whole new exhaust kit with new pipes and mufflers. If your doing it yourself the only tools you should need are a hacksaw, socket wrench for the clamps (if you choose this route), some dish soap for the hangers and most importantly a 6 pack. I think this should answer your question....??
Old Mar 26, 2007 | 06:09 PM
Car: Firebird 1989
Engine: 2.8 Litre
Re: How Hard is it?
YOu are the man!!! But now Auto Brother is the 6-pack before or after the job is done?
Old Mar 26, 2007 | 06:45 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: How Hard is it?
6 pack before working on a thirdgen = buzzkill.
6 pack after finished working on said thirgen = we rejoice.
Old Mar 27, 2007 | 09:25 AM
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
Re: How Hard is it?
mine was a b!tch to get off, i cut it off, i baught a force pro series muffler from jegs for $35 and went to autozone and got a 90* bend and a 1' straight peice and put one dump in the back drivers side, sounded awsome and was cheap
RedLeader289
May 28, 2019 01:47 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
loud91rs
Oct 5, 2015 10:05 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
