a few questions setting up custom exhaust
Old Mar 26, 2007 | 03:47 PM
RyanFromSC's Avatar
Car: 1990 RS
Engine: 305 tbi
Axle/Gears: 10-bolt 2.73 open
ok here's the deal...I don't know what I should do with the exhaust on my 88 IROC. I'm swapping out the trashed 350 with a 350 from a 92 Z/28. Also, I'm putting Summit 2.5" headers on it. I want to run pipes in front of the rear axle with turn downs and 40 series Flowmaster mufflers. Now, should I use 2.5" piping or go for 3"? should I get better and/or larger diameter headers? Is this a stupid idea in the first place? I've seen so many different setups, I just need a little advice and claficication. Thanks.
Old Mar 26, 2007 | 06:14 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: a few questions setting up custom exhaust
Have you already bought the 2 1/2" headers?
Old Mar 26, 2007 | 07:15 PM
Pennocks91ws6's Avatar
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
buy the hedman or hooker headers for an extra 20- 50 bucks,,, they got 3 inch .
dual out before the tires is very hard to do with good ground clearance,, especially with big flowmaster mufflers.
Old Mar 26, 2007 | 08:16 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
I think he means turndowns in front of the axle. Your really in a no win situation here. The floorpan just isn't shaped correctly to cleanly accept duals. Do a search or look for a sticky. Somewhere on this board someone made a posting showing everyones exhaust.
Old Mar 26, 2007 | 09:41 PM
RyanFromSC's Avatar
Car: 1990 RS
Engine: 305 tbi
yeah I've already got the 2 1/2"s. I was planning on getting better ones later on...these are just preliminary I guess you could say. I figured ground clearance would be the main issue...before removing the s*** engine, it had the stock manifolds and y-pipe into a flowmaster single chamber (and thats it, no pipes, nothin) and the dang muffler was maybe 2 inches from the ground? I dunno. So do you guys think I'd be better off just running it out the back, or maybe having it exit right behind the rear axle? I appreciate everyone's input. Thanks.
Old Mar 26, 2007 | 11:06 PM
Car: 91 formula ws6
go with a single 3 inch back from pretty much any company, thatll be plenty for a 350
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
kah992
Aug 19, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
