need to peice together a Y-pipe..whats needed?
Old Apr 7, 2007 | 07:58 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I gotta get some madrel bent tubing to make a Y-pipe from my hooker long tubes to my intermidiate pipe from my cat back borla...
I have no clue what to get.....can any help me figure out or poiny me to what I need? what kinf of ypipe tube?
Ive seen the around but dont know where people get thier stuff
Old Apr 8, 2007 | 11:46 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Re: need to peice together a Y-pipe..whats needed?
Get it from Thunder Racing, Dave Tuschoff. You will need some header flanges, six feet of three inch tubing from NAPA, and two 90 degree bends that you will cut in half to make four 45's. You may wither choose to roll your own merge (like I did) or else buy the Flowmaster merge, but it's a long puppy. I've got the Flowmaster merge sitting around my house: I didnt use it, and probably wont ever use it. I'll sell it for $35 if you want it.
You'll also want a 3.5-inch to 3-inch reducer for the exit, and either use a stainless steel band clamp as a slip-fit, or else get yourself another pair of header flanges and some gaskets from Thunder for that particular connection.
Lastly, you need to weld in some kind of exhaust hanger. Thunder Racing has them as well, and these are a hanger that gets bolted to your floorboard, then is clamped or welded onto the Y-pipe, with a rubber isolator in the middle.
Go here for my fabrication pictures and head to the random pictures section.
http://www.ws6transam.org/Gallery
Old Apr 8, 2007 | 12:04 PM
whats a flowmaster merge? the Y part? if its what I need then I'll more than likely take it off your hands...got a picture of it?
I looked at your pictures...but remember Im going under the cross memeber cause of the 700r4.
on a side note,,,take a listen to my cam in the HSR section and tell me what you think..its open headers but i dont have exhaust run yet
thanks!
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
