y pipe size and header type power comparision needed
Old Apr 6, 2007 | 05:00 PM
speedmachine's Avatar
Car: 1989 IROC-Z
Engine: 346 LS6
Axle/Gears: Hybrid 8.8 3.73
hello
I am currently planning to use longtube hedman hedders [ 3 inch collector] and make a 2 1/4 inch y pipe that goes around the tranny into a 3" back. Would this be better or worse than midlength hedders with a 2 1/2 inch y pipe in the stock routing location?
Someone please shed some light
Lee
Old Apr 6, 2007 | 05:32 PM
ZROLimitRacing's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 5.0 305 Code H
Re: y pipe size and header type power comparision needed
why not just go 3 inch all the way????
Old Apr 6, 2007 | 06:32 PM
Car: 1989 IROC-Z
Engine: 346 LS6
i would love to but ground clearance would be a major problem considering that the y ypipe would have to go over the automatic tranny crossmember to use my longtubes.
So for now i just need suggestion on whitch of the two i posted are better.
Speed
Old Apr 7, 2007 | 03:49 PM
well if ground clearence is an issue try some ovalized pipe
Old Apr 7, 2007 | 09:41 PM
Car: 1989 IROC-Z
Engine: 346 LS6
thats a good idea i haddnt thought of that, is there somewhere i can but it, or do i put normal pipe the the vice?
thanks
speed
Old Apr 8, 2007 | 11:53 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
CHeck the thread on "BOOM TUBES" I believe there are several links in that thread that reference where to buy oval tubing. No, you cannot squish it in a vise to make oval tubing. As you squish, the cross-sectional area gets reduced. Oval tubing has a larger circumference to ensure that the cross-sectional area remains constant through the whole length.
Old Apr 8, 2007 | 01:17 PM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Another option is to run hooker 2055hkr...they come with a 3" Y-pipe then run a 3" all the way back into a 3" inlet muffler with dual 2 1/2 outs.
colton_carlson
Mar 8, 2019 12:21 PM
IROCZ1989
Jan 24, 2016 03:55 PM
Wvcamaro
Sep 4, 2015 08:38 PM
knight72
Aug 10, 2015 09:32 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
