I found this exhaust setup on ebay...
Old Apr 10, 2007 | 02:06 AM
pray4chicken's Avatar
Car: 85 camaro berlinetta
Engine: 2.8L
Transmission: auto
what do you guys think of this ? ...i'm considering getting it.
http://cgi.ebay.com/ebaymotors/1982-...QQcmdZViewItem
Old Apr 10, 2007 | 02:12 AM
85irocz355tpi's Avatar
Car: 85 IROC-Z
Engine: 355 TPI
Transmission: 700R4w/Shift Kit
Axle/Gears: B/W 9 Bolt-3.45
Re: I found this exhaust setup on ebay...
It looks good check out mine.
Old Apr 10, 2007 | 02:15 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
yeah that looks good, too bad he didn't use 3 inch all the way, would this affect back pressure not having a muffler?
Old Apr 10, 2007 | 02:19 AM
Car: 85 IROC-Z
Engine: 355 TPI
With all the pipe you'll be fine. I cut off the muffler on my first camaro and had no trouble
The duals I ran really look and sound cool. It's relatively simple takes a little modification but as long as you have good shocks and struts it works well.
I also ran flowtech headers.
Last edited by 85irocz355tpi; Apr 10, 2007 at 02:21 AM. Reason: Automerged Doublepost
Old Apr 10, 2007 | 03:21 AM
Engine: 2.8L
Transmission: auto
would anyone here get this ? If i dont get it...i'm gonna go with a flowmaster.
Old Apr 10, 2007 | 11:03 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not me. See that "T" where the (as already mentioned small) I-pipe goes to the two tailpipes? Horrible for flow (but then, how much can a 2.8l flow?). It's not a muffler, so it would be a ticket magnet.
That's a big "pass", IMHO. Get a real exhaust system.
Old Apr 10, 2007 | 11:54 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
WHAT A P.O.S!
Old Apr 10, 2007 | 01:08 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
That exhaust is only 2-1/4 and the bends suck !
Old Apr 10, 2007 | 01:21 PM
RWB____s's Avatar
Car: Z/28
Engine: 355
Transmission: Turbo 400
Non of the bends are mandrel bent. The elbow bends look like an accordian
Old Apr 10, 2007 | 01:45 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Hmmm....just cut your muffler off and have them run the exhaust out the back without it, it will save you money and make more power over that hack job, good luck...
Old Apr 10, 2007 | 06:03 PM
Engine: 2.8L
Transmission: auto
guys for the info...i'll most def will not buy this thing then ...peace.
Old Apr 10, 2007 | 07:37 PM
DaSkinnyGuy's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
Since there is a 2 1/4 inch pipe coming from the cat there is no sense in getting it. The bigger the pipe size the better the sound. Just get a GMMG Chambered exhaust best sound out there. I didnt realize u had a 2.8L you should just get a flowmaster 80 series
Old Apr 10, 2007 | 08:17 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Exactly my thoughts!
Its bad enough he uses small pipe, but then they top it off with chitty bends to make it flow even worse!
But like said above, on a 2.8 its probably sufficient. Definately a pass on a larger cube motor.
Old Apr 10, 2007 | 10:36 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
If you want a decent exhaust for not a ton of money get the Dynomax set up. True mandrel bends and aluminized pipe. I had one on my old 2.8 Camaro and it was pretty decent for what it was.
Old Apr 11, 2007 | 01:53 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Well...Looks kinda bad. Save your money and buy somthin you really like. Looks like an autozone special....People will laugh at you!
Old Apr 12, 2007 | 10:46 PM
Engine: 2.8L
Transmission: auto
damn , i wouldnt want that hahah
Old Apr 12, 2007 | 11:24 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
go with a dynomax, you'll be more than happy with it.
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Apr 30, 2019 12:14 PM
gta90
Sep 15, 2015 04:00 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
