T5 and hedman 68460....possible?
Old Apr 29, 2007 | 07:53 PM
tpoch845's Avatar
Car: 92 'bird
Transmission: 700r4, T5 in the garage
This is probably been asked a hundred times, but I can't think of the right keywords to search...I have already ordered and recieved the headers for my engine swap project, and I would really like to install the T5 (I yanked a dead 3.1L outta my 90 RS, and the 700r4 is obviously no good to me). I found a guy local that will sell me the t5 and all of the necessary hardware CHEAP. Then I remembered that Summit said that this combo is not possible. Are they right? Any way around this? Any help is appreciated!
Old May 2, 2007 | 08:22 PM
84ZMIKE's Avatar
Car: 84Z28
Engine: 0.030 over 10.25:1 dart heads 350
Transmission: T 5 W.C. now
Axle/Gears: 3.73:1
Re: T5 and hedman 68460....possible?
It can be done...the only issue is with the slave cylinder....the primaries will not allow the header to fit without modifications.....I used a floor jack and a propane torch to bend mine then cut the flange off and am in the process of fabricating the end back on.
Old May 2, 2007 | 11:06 PM
z28freak84's Avatar
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
OR...A simple Ding in the collector does the trick. Search for ChevyMec. He has this and I believe has some pics somewhere around here. If not search the same name on fbody.com.
Zell1luk
Sep 29, 2015 10:36 AM
italiano67
Sep 22, 2015 08:42 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
cstrobel65
Sep 16, 2015 11:54 AM
WickedBowtie
Sep 11, 2015 11:24 PM
