Exhaust smoking A TON
Car: 1986 Camaro Iroc-z
Transmission: 700r4 w/ custom shift kit
When i bought my car it had a little smoke to it when i started it but now its smoking up a cloud behind it, any valves to check for or??
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Exhaust smoking A TON
is it smoke or steam? steam would mean a cracked head, excessive smoke could be a leaky exhaust valve seal, or the best case scenario, you just have a leaky valve cover and its dripping on you exhaust.
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
what color is the smoke? if it's blue it's oil and thats bad. if its white and sweet smellin its coolant and thats bad too(blown head gasket) and dark or black smoke is fuel and that can usually be corrected.
It's a mixture of blue and white smoke...how much do gaskets run for ?
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Worn valve seals are a pretty common problem with these engines once they hit 100K miles. They give off that blue-ish smoke because the oil in the heads leaks down past the valve seals into the combustion chambers and gets ignited with your mix when you start 'er up.
