Interesting o2
Old May 17, 2007 | 12:18 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
Interesting o2
i was attempting to install headmen headers w/o o2 and figured..eh cant be that hard to weld the old one in....i checked the location of the stock o2 and followed the wires down to around the bellhousing and realized>it isnt even hooked up, not only could i not find where the plug goes for the 02 but couldnt figure out why it has no effect on my cars performance considering it cant be reading anything....ideas anyone?
Old May 17, 2007 | 04:16 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: Interesting o2
hello blimko, this is blimko and i cant tell you anythin about what your asking because it should run like shi* if your 02 isnt plugged in at all, and no its not all that hard to relocate the o2 sensor to your non o2 headmens, the hardest thing will be getting the manifolds off cuz the pass side rear bolts are a pain. anyway, i'll keep waiting for someone to help you becausei cant do it. your welcome for these tips though.
Old May 17, 2007 | 06:24 PM
gibsongod716's Avatar
Car: 85 Trans Am / 64 Chevy Nova
Engine: Turbocharged 355ci / 383ci
Transmission: WC T-5 / T10
Axle/Gears: 3.45 / 4.11
Re: Interesting o2
my car has been running great and i just realized two days ago that my o2 sensor has not been plugged in for god knows how long, so i really dont think the o2 sensor does much for the car and/or performance...
Old May 17, 2007 | 10:34 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: Interesting o2
from reading and learning on here, i ave to disagree
Old May 18, 2007 | 11:20 AM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Re: Interesting o2
Correct, the 02 sensor is one of the main components that determines your air to fuel ratio. Without it your always in open loop running rich and using the fuel tables that the ecm originally came programmmed with and which dont fit your engine "perfectly"
Old May 18, 2007 | 12:20 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: Interesting o2
so what should i do i noticed that when my car sits and i start it it puffs blue but doesnt run low on oil, this could be the reason, i just thought i had worn valve seals, can someone tell me where the o2 sensor connector plugs into? i cant locate it for the life of me. also, why am i not getting a code light>
Old May 18, 2007 | 06:05 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
Re: Interesting o2
wierd your not getting a ses light. the puff of blue smoke is worn valve seals, easy job just time consuming. the connector to the o2 sensor should be near the drivers side frame rail, and feeds up towards the firewall.
if u cant find it i bet it is cut of because, its very easy to see
Old May 18, 2007 | 08:55 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: Interesting o2
yes i was wondering if the previous owner, i beleive they had work done to the motor of some sort im not sure what, must have never connected this and maybe had it erased from the ecm but idk. i will check it out tomrrow well putting my headers on
Old May 20, 2007 | 08:51 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Re: Interesting o2
Just maybe the ses bulb is burned out from having been on so long.....OR the PO removed said light to hide the fact there is an O2 problem. Gibson....just imagine how much better it will run if you get it to run correctly.....and how much less fuel you will burn!
Old May 22, 2007 | 09:17 PM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
Re: Interesting o2
Mine was disconnected for a few days (Forgot to plug it back in after workin on it) and I only got a SES light while cruising at a very steady 55ish MPH.
Old May 23, 2007 | 12:46 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
Re: Interesting o2
possibly limp home mode, that can work i suppose, but i would get a new 02 sensor, that way you know it's good
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
mattcanty
Oct 12, 2015 11:08 AM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
Eric-86sc
Sep 28, 2015 11:37 AM
6998poncho
Sep 25, 2015 02:56 PM
