intermidiate pipe removal
Old May 17, 2007 | 04:07 PM
j dezzy's Avatar
Car: 87 TA
I just picked up a new car, 87 TA. car is great, except the exhaust...muffler is new but the intermidiate pipe is full of rust holes, so I cut it out...now, my 84 TA has a new intermidiate pipe on it and is getting shipped to my garage in WV so that I can start the body work and put the new engine in. so it won't be needing its exhaust any time soon....I've got it's intermidiate pipe disconnected from the cat and the muffler is off....But I can't get the pipe to go over the rear end at all...any tips short of cutting the pipe?
Old May 17, 2007 | 04:12 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: intermidiate pipe removal
I dont see why you cant get it over the rear. I just through mine right over the axle without any problem at all. Are you positive you are putting it on the right way?
Old May 17, 2007 | 04:15 PM
j dezzy's Avatar
Car: 87 TA
It's not trouble putting it on, I can't get it off my 84 to put on my 87. It just won't go over forward or backward. can't clear it by about 2 inches going forward, and pulling it out the back it seems like it would never fit...
Old May 18, 2007 | 05:21 AM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Jack the rear of the car up and disconnect your shocks and panhard bar so that you can lower the rear end. This is what I had to do when installing my Dynomax cat back. Good luck.
Old May 18, 2007 | 07:45 AM
j dezzy's Avatar
Car: 87 TA
I already disconnected the panhard bar to give myself a little more clearance. I'll try dropping the rear. thanks
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
