wow
Old May 28, 2007 | 08:01 AM
MattSloc's Avatar
Car: 1986 Camaro Iroc-z
Transmission: 700r4 w/ custom shift kit
wow
so im putting the exhaust manifold back onto the heads on the passenger side. the heads are remaned) all the bolts match up except the last closest to the firewall is an inch off ?! if i bolted all five in but that it would overlap the one bolt...what should i do
Old May 28, 2007 | 08:08 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: wow
Ive never heard of that happeneing. Your idea wont work, not for a half of inch.
Old May 28, 2007 | 11:54 AM
chris75605's Avatar
Car: 84z28
Engine: 327
Transmission: t56
Re: wow
looks like you got an older set of heads, i ran into that problem once. in about 1980 they started putting seven bolt holes in the head and all the f-bodys used the extra one. you only have two options, get the shop you got the heads from to exchange them or get some headers, they all have the older style flange.
Old May 28, 2007 | 12:46 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Re: wow
There is also a company that makes adapter plates to go in between the head and the manifold that has an allen head tapered bolt, that goes into the head in the rear most hole, and has a tapped hole in the correct place to bolt the manifold to. It is about 30 or 40 bucks, and works pretty well, but it's another place to worry about a leak. I wish I could remember the company that makes it though....
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
vortech305
Oct 30, 2001 08:25 PM
JeffC1500TBI
Oct 23, 2001 11:01 PM
five0beatr Z28
Aug 11, 2001 09:12 PM
