Headers for TBI question
Old Jun 13, 2007 | 01:39 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Looking towards the winter I am thinking of adding Headers to my stock 305. I am thinking of adding the below listed headers. This is what the add says.
MAC True Fit Header system is made of 1 5/8" 16ga. tubing, complete with a 2.5 Y-pipe and 3" collector.
Anyone with knowledge on this system? Yea or Nea. If Nea where or what should I get. Just looking for improved performance. I don't race the car, just want my engine to breat a little more. The advertisement says 21 hp increase.
Old Jun 13, 2007 | 03:03 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
Re: Headers for TBI question
that advertisement is not relative to your 305. it will increase..something..but not a noticable gain unless you put air into it. 305 tbi's are equipped with the poorest of heads and the most restrictive throttle bodies along with a crap air cleaner and air intake set up, AND low flowing intakes AANNDD low flowing exhaust manifolds...SO..if you wanna get "alittle" performance this is what i would suggest. ditch the setup you wish for and check into hooker 2055?? or a set of headmens. make sure what you get are shorties..also you will need a y pipe that you can match up when you get your headers. NEXT, your tbi system has all the lovely smogger options on it and NO you dont need to remove them but YES i would highly encourage you to do so. purchase a set of NON A/I/R headers with an O2 BUNG already on the headers, unless your a decent welder and are capable of installing it yourself. also you'll need the proper gaskets for your header to y pipe application. it may take collecter gaskets or the donut gaskets. make sure you buy a good set of header gaskets as well..SPEND the extra couple of dollars on some copper gaskets or good standard gaskets TRUST ME..ALsO get a good set of header bolts, all the extra's can be found at a local parts store. now, thats just half of it. the next half is cat-back...putting a set of 1 5/8 headers wit 3 inch collectors on and connecting to a 2.25 inch exhaust with a 19 year old cat back is plain useless..you need to open that baby up to a good 3 inch remove the cat or get an aftermarket high flow cat 3 inch all the way to the tail pipes located just after your brand new aftermarket muffler! now throw in a good open element air cleaner, some tbi mods, or go to carburated which i am in the process of..let me know if this helped you at all.
Old Jun 13, 2007 | 03:54 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Yupperz thats about it.
Before any mods I suggest doing a tune up:
Plugs, Wires, Cap and Rotor, Oil Change, SEAFOAM
Then K&N 14x3 open Element, Hookers 2460 headers (Y-Pipe HOK-16767HKR)or 2055 for full assembly or Hedmans 68476 headers (Y-Pipe 17470)
Old Jun 17, 2007 | 05:44 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Mac performance haders are Excellent. Go with the ceramic coated ones.
Read the tread "Hoocker vs Mac performance vs (dont remember)" in the exhaust section. I wrote some memories on istallation. Like the other members say'd you should do the complete exhaust + air intake probably + chip to have the stated hp increase.
Old Jun 19, 2007 | 08:34 AM
Axle/Gears: Posi
What is SEAFOAM?
Old Jun 19, 2007 | 02:40 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
What is SEAFOAM?
http://www.seafoamsales.com/motorTuneUpTech.htm
MustangBeater20
Oct 29, 2022 09:20 PM
dutch930
Sep 11, 2015 06:58 AM
InfinityShade
Aug 22, 2015 08:00 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
