video clip
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
video clip
just thought id throw this up, good little clip of me getting into it a little bit, figured itd fit in here nice as an exhaust note clip.
the car is a mild 355, basically the heads are garbage iron heads that barely outflow stock, but its got a 274 cam with a stealth ram so lots of potential.
The exhaust is old school slp headers that really need replacing, keep loosening the header bolts out cause the tubes are all warped, not sure why in the hell they dont make their headers with a solid flange. Goes back into a mandrel bent 3" system, with a magnaflow 3" in and out muffler behind the axel, with a single pipe ending just before the bottom of the bodywork so ya cant really see it.
in the video i kind of freak out cause i over revved the thing lol, my posi's on its last legs so i get 1 wheel peel. Didnt even realize till recently that somehow my car got a set of 1LE brakes at some point in its life so i spent 500 bucks on pads and rotors for all 4 corners, thing stops so hard and my suspensions so crap that i bottom out the air damn pretty hard lol.
here it is http://s95.photobucket.com/albums/l1...t=f3372f08.flv
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: video clip
Weak sauce....just kidding, i like it, not loud enough for me though.
Car: 1990 Camaro
Engine: 355ci
Re: video clip
turn your speakers up
i know its not that loud, had chambereds on it before and it was silly loud. I like it pretty quiet at idle and cruising, but when you get to 5000 (pull till 6) it freakin screams
i know its not that loud, had chambereds on it before and it was silly loud. I like it pretty quiet at idle and cruising, but when you get to 5000 (pull till 6) it freakin screams Thread
Night rider327
Feb 25, 2016 09:50 AM
