stock replacment y pipe
Old Aug 8, 2007 | 09:08 PM
blue_iroc_z28's Avatar
Car: 1987 pontiac trans am gta
Transmission: 5 speed
Axle/Gears: 3.43 posi
does anyone know where to get a replacement y pipe, new or used.aftermarket is fine as long as it can bolt up to my stock manafolds (305 tpi ) i went to a muffler shop and they wanted $434.00 for ypipe and labor . i thought about the junk yard but it would be hard to get to it in the yard .i dont have a lot of money at the moment so the cheaper the better , thanks for any help
Old Aug 9, 2007 | 05:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: stock replacment y pipe
Barring the JY, you might consider the classifieds on this site.
JamesC
Old Aug 9, 2007 | 07:39 AM
kcgperformance's Avatar
Car: 88 RS Camaro (Z28 Clone)
Engine: LS6, Vengeance VRX5
Transmission: T56, LS7 Clutch
Axle/Gears: Moser 12 bolt 3.73:1 ratio
Go to Napa Tell them what you have. I found part number: EXH 40439 for a total of $204.00 . Pick up the Y pipe from them and install it your self with some new gaskets.
-Kevin
Old Aug 9, 2007 | 04:25 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Try jegs, they have a new Y-Pipe setup jsut for our cars in the TPI section. Stock replacements....minus cats of course.
Old Aug 9, 2007 | 04:41 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
blue iroc z28,
On Rockauto.com you can find the stock y pipes for around 125$.
If you use 3" cat converter, macperformance.com sells a nice one for around 170$. (the same one can be found at hawks)
Old Aug 10, 2007 | 02:37 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
JUNKYARD!!!
Old Aug 10, 2007 | 04:58 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
yah man, junkyard it up. no reason to pay 200$ for anything "stock" in reference to the exhaust system...
Old Aug 10, 2007 | 01:24 PM
thanks for all the replys, i think i found one for sale near me , but before i go look at it is there any difference between tpi and not tpi y pipes? i saw somewhere that iroc exhaust is bigger (im a camaro noob)
Old Aug 10, 2007 | 02:42 PM
JamesC's Avatar
Yes. The LG4 Y-pipe is smaller and will not fit the TPI exhaust manifolds. FYI, some IROC's were equipped with LG4's, so not all had the larger exhausts. The following link will provide some more info:
https://www.thirdgen.org/forums/exha...-question.html
JamesC
Old Aug 10, 2007 | 04:48 PM
ok that will help out a lot thanks for that. that pic is good reference, i have the bigger y pipe. i did not know there was that much of a difference in the 2. thanks for all the help
Old Aug 11, 2007 | 02:55 AM
Tobias05's Avatar
ya man, the LG4 y-pipe looks like a friggin snorkel.
Old Aug 11, 2007 | 05:36 AM
JamesC's Avatar
If it were only that big .
JamesC
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
marcusaw
Aug 10, 2015 08:13 AM
