hooker 2210 LTs going to hit my slave cylinder?
Old Aug 20, 2007 | 11:26 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
i have a lakewood bellhousing for a tko-600 and hooker comp shorties already dont fit because the flange on the passenger side didnt clear the bellhousing.
Are hooker LT's going to hit my slave cylinder here on the drivers side?
Old Aug 21, 2007 | 09:16 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Re: hooker 2210 LTs going to hit my slave cylinder?
I have the lakewood bellhousing and I'm running the long tube 2210. They clear fine. However, to get the driver's side header in I had to jack the motor up.
Old Aug 21, 2007 | 10:09 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
awesome thanks
Old Aug 21, 2007 | 07:48 PM
AC's Avatar
AC
Car: Used to drive a camaro
Doesn't hit but gets CLOSE. Heat protective wrap is your friend.
Old Aug 22, 2007 | 11:14 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
good to know, im installing the long tubes in the driveway then driving to a shop to get my exhaust hooked up to it. I'll just get them to put heat wrap anywhere thats close to touching important things
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Chevykid810
Sep 28, 2015 12:57 PM
BLK87Z
Sep 18, 2015 11:29 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
armybyrd
Sep 15, 2015 06:06 PM
