Thudding Sound from exhaust pipes
Old Aug 29, 2007 | 08:06 AM
The Shadow's Avatar
Car: 1989 Camaro RS
Engine: 305 V8 TBI
Does anyone know why you would get a thudding sound from your exhaust pipe. At idle the sound is similar to pouring oil out of the bottle, its a continuous thud thud thud thud sound or a low muffled pop pop pop pop sound coming from the exhaust.
Old Aug 30, 2007 | 01:17 AM
blackbird615's Avatar
Car: 1991 Trans-Am "Blackbird"
Engine: 305TPI LB9
Axle/Gears: Hmm
Re: Thudding Sound from exhaust pipes
I think I had the same problem you do... My reason was the fact that 3 injectors were stuck open shooting raw fuel down my cylinders- causing my engine to run rich, very rich. the thudding could possibly be unburnt fuel igniting periodically or every second or so, in the exhaust. do you have a cat? not having a cat will contribute to that noise if you're running rich... Just somethin' to check out
Stock exhaust? Engine size? Cat's? More info dude!
Old Sep 1, 2007 | 09:22 AM
86FireBird305's Avatar
Car: 1986 Firebird LG4
Engine: 305 5.0 LG4
Transmission: TH-700R4
you could simply have a small backfire issue. check your timing and wires,plugs,dist. etc.
billybob6110
Sep 24, 2016 09:50 AM
db057
Sep 4, 2015 07:57 AM
downsouthboy
Aug 29, 2015 11:29 AM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
