can I run a test pipe in Ohio?
Old Sep 10, 2007 | 01:22 AM
ohiotemplar's Avatar
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
I googled this and came up with alot of folklore, but no one seems to know for sure if I can go without the cat here in Ohio. I have the "looks like dual exhaust" $280 bolt on flowmaster exhaust. The cat looks pretty unsubstantial anyway, I don't know if removing such litle restriction would even let me breath better anyway. Advice?
Old Sep 10, 2007 | 06:05 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: can I run a test pipe in Ohio?
from ohio, still have ohio plates/registration. i tore mine out a long time ago. i even drove by the local cop with open headers(just once) one day after school a few years ago.
as long as you don't run around with open pipes/ no exhaust and making a fool of yourself no one will care. with that flowmaster cat-back no one will notice.
Old Sep 10, 2007 | 08:10 AM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
There are a few counties with no emissions checking. Find out if you are in one and you are in the clear. Also (thread jack) I have a test pipe I need to sell before I move. PM for more info. (thread jack over)
Old Sep 10, 2007 | 09:30 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Its not a STATE LAW thing. Emmissions stuff if a FEDERAL LAW.
Can you get away with it... Ya for sure. as long as you dont have e-check.
Old Sep 10, 2007 | 05:04 PM
Engine: 3.1 V6 MFI
thanks guys, I'm convinced - the cat has to go - soultron - I would but I got a guy that's gonna do it 30$ installed with part. Seems good to me. Since we're talking about pollution laws... I read a mention in an old post that said something about how you can remove the air pump to increase engine efficiency? Is that true? It was vague, I'll try and find it again tonight and link it here.
Old Sep 12, 2007 | 10:49 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Should have no problems in Athens. I'd suggest taking the converter off and rodding it out, reinstall. Pretty easy job. The air pump uses about 2 horsepower and has nothing to do with efficiency. Puts air into the manifolds when the engine is cold to speed up the cat. heatup/reaction, then pumps into the middle of the converter to help the secondary reaction.
Old Sep 13, 2007 | 03:21 AM
Engine: 3.1 V6 MFI
What would the best way be to bore out the converter? I'm totally into doing things as cheaply as possible - then I can do more
Old Sep 13, 2007 | 07:08 AM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
FWIW, I ran mine with an "off road" pipe for a while, then e-check was introduced in my area. I bought a high flow cat for emissions check purposes. The car ran better with the cat installed. There was actually a "seat-of-the-pants" difference. It felt much more responsive and torquey. I've left the cat installed and pitched my off road pipe.
Dave
Old Sep 13, 2007 | 10:33 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
agreed. the states don't make these laws just on if they want to enforce them or not.
also as others have said to just gut the cat out only way I would do that is if you put a pipe through it. at least that way it looks like a cat even yet gives you the performance of a straight pipe rather then the not as good performance of a empty gutted cat.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
transaero
Aug 31, 2015 01:14 AM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
