I have two exhaust questions....
Old Oct 25, 2007 | 04:51 PM
ndamron's Avatar
Car: 82 Trans-Am / 83 Trans-Am
Engine: Major Mod SBC / Minor Mod SBC
Transmission: Major Overhaul 700R4 / Stock 700R4
Axle/Gears: None!!! / 3.73 posi disc...soon
Does anyone know if the Mufflex system will work with my sophn crossmember and TQ-Arm. I have both the front and rear driveshaft loops. I'm running the hooker 2210's.
2nd, Does anyone know where a guy could get some 3in oval exhaust tubes in case the mufflex system wont work?
thanks all!
Nick
Old Oct 26, 2007 | 06:29 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Re: I have two exhaust questions....
Yes the mufflex will work with the Spohn Cossmember and torque arm. I had no problems with the fit when I had mine.
Old Oct 26, 2007 | 11:04 PM
Bandit5's Avatar
I have just about every single piece of suspension that Spohn makes and a Moser 9" in my car. I just had the 4" Mufflex system put on last week. Because I used long tube headers, I had a ground clearance issue at first, but then I had the sub frame connectors notched out and boxed in, and had a custom exhaust guy put in for me with custom bent pipe. The end result is absolutely fantastic. I will try to get some pictures of it next week when I have it up on the lift to put in new shocks/struts.
Yes it fits, but to get it to fit nice, I would suggest having it done professionally as the stock hangers will make it pretty low.
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
