cap and rotor
Old Nov 1, 2007 | 07:57 PM
86transamkid86's Avatar
Car: 1986 trans am
Engine: 305 tpi
Transmission: ?
Axle/Gears: 2.73/stoke/soon to be 3.47
cap and rotor
i changed my cap and rotor to an msd along w/ msd wires so the prob. was that it was making a clickin sound every time i hit the gas down a lil above half way so i could not go above 45 or it would be a constant clickin so this was doin it sense i put it in so i changed it back to the stock one and now it does not do it so wut is the prob. w/ the msd cap and rotor is it to powerful? do i also need to change the distibuter? i have no clue as to the prob. but i do know that that was $80 dollers out the window because i cant use it so any ideas would be appr. thanks
im sorry i did not realize i put this in the exhuast forum i ment to put this in the electronics parts sorry dont kno how to change so im goin to try to copy and past
Last edited by 86transamkid86; Nov 1, 2007 at 08:01 PM. Reason: Automerged Doublepost
Old Nov 1, 2007 | 08:13 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: cap and rotor
hmmm wierd, i know an exhaust manifold gasket leak will click like a time bomb.......LOL..will it do it if you rev it up in park?? does it seem to do it at a certian RPM or MPH .... just tring to put some more things together here...........but if if the stock one is total quiet then maybe you have a defect in the cap and all, im running all MSD and its totaly quiet
Old Nov 1, 2007 | 09:39 PM
Car: 1986 trans am
Engine: 305 tpi
Transmission: ?
Re: cap and rotor
well it does it when i step om the gas like half way but then if i go above 45 it does it even if you hit the gas lightly but when you 1 st start the car and step on the gas hard it does not do it, its like when the car gets warmed up after about 15 min of drivein and no it does not do it if i rev it and i have not looked at the rpm to see if it does it at a certain rpm but if i had to guess it would prob. be around 2000 rpm
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
tyeo098
Nov 30, 2015 06:27 PM
BLK87Z
Sep 18, 2015 11:29 PM
m00n420
Sep 11, 2015 02:39 PM
