header/y-pipe install gone wrong.. need help
Old Nov 4, 2007 | 11:39 PM
Deshi00's Avatar
Ran into a few problems on this install. Its hedman shortys and y pipe to match by the way. Installing the headers, big pain but eventually got them in. Started the car and it ran fine. Put the y pipe/cat. on next, install went fine. Went to start the car heard a loud knocking, sounded like the y pipe hitting the oil pan, then the car died. Took the y pipe off and started it again just to make sure, it ran fine, grinded down the y pipe just a bit then bolted it back up, had the same problem, i think its still hitting the oil pan but that doesnt explain why my car would die... anyone have any ideas
oh yeah as i was moving the car my breaks dident seem to be working right, the pedal was really stiff, is this just unlucky timing or could i have damaged the master cylinder tryin to stuff those headers in or anyone have any other ideas about this? thanks
Old Nov 4, 2007 | 11:49 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: header/y-pipe install gone wrong.. need help
I dont think the Y-pipe is the problem it should vibrate the same as your engine. Sounds like you unplugged a vacume line durring the install by the power brake comment. as far as the knocking, look for the exaust comming in contact with the body or any thing fixed to the body.
Old Nov 5, 2007 | 12:42 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
It died? Yea, check the brake booster line and see if you cat might be clogged maybe.
Old Nov 5, 2007 | 11:58 AM
Deshi00's Avatar
thanks ill check some of that. the cat is brand new so i would hope its not cloged
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
