headmen 68470 headers and 17470 ypipe fitment
Old Nov 10, 2007 | 10:05 AM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
who has these and how do they fit?
what are the sizes of the piping on the y pipe?
i had flowtechs on another car and they weere **** for fitment
thanks
joe
Old Nov 11, 2007 | 09:40 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Don't have them, but nobody else has responded.
The pipe is 2-1/2" after the "Y" with an adapter to fit the 3" cat inlet. Several members have cut them at the "Y" and put in a Flowmaster 3" outlet "Y", for a 3" inlet to the cat.
Old Nov 12, 2007 | 03:31 PM
400 hp's Avatar
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
Re: headmen 68470 headers and 17470 ypipe fitment
im running headman headers and y pipe fit is good on the headers.. the y is ok
2 1/4 to 2 1/2 and 3'' adapter.. at some pont i will mod the y to full 3'' at the back were it meets the cat i dont like the adapter..im happy with it..
Old Nov 15, 2007 | 11:49 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
These fit fine. I had to modify the y-pipe to make it 3", and to keep it from hitting my SFC's.
Old Nov 15, 2007 | 01:39 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
my headmans fit great little moving of things to get them in but all in all the headers fit well along with the y pipe. only problems you might run into are the cooling tube on the passenger side running down near the header(hard line) might touch or be damn close so you might have to bend it out of the way you definately dont want a hole rubbed in that. and second off watch for the y pipe hitting the oil pan the right adjustment itll clear if not youll hear a little rattle around there.
o and the ball and socket flange works great fits great and seals great too.
Last edited by vipershark11; Nov 15, 2007 at 01:40 PM. Reason: Automerged Doublepost
Old Nov 15, 2007 | 07:51 PM
jerflash's Avatar
how is the clearence on the passanger side frame rail?
when i had flowtechs...it hit there very badly
Old Nov 15, 2007 | 11:06 PM
Sonix's Avatar
Car: 1982 Trans-Am
Stock it wouldn't clear the SFC, i'm not sure if I didn't have SFC's how close it would have been to the sub frame. I'd just chop it at the Y part, and weld on a 3" mandrel bend there and connect it to your piping.
Old Nov 15, 2007 | 11:59 PM
Engine: LO3
near the frame i dont believe mine hits there i havent driven or looked at my car in a while but pretty sure it never hit. all in all the headers and matching y are a great product and shouldnt be dissappointed.
Old Nov 18, 2007 | 09:02 PM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
are these similar to the 68460?
Old Nov 19, 2007 | 09:18 AM
Sonix's Avatar
Car: 1982 Trans-Am
IIRC, 68460 is with the older 3bolt flange, 68470 is with the newer ball and socket style. 17470 y-pipe never had the part number changed when it changed designs, 3-4 years ago IIRC.
Old Nov 20, 2007 | 04:37 PM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
i have a crate motor with a deep oil pan. the drivers side of the "y" pipe didnt fit around my oil pan. my mechanics had to physically abuse the left side of the y pipe to get it in between the crossmember and the oil pan.
other than that they work fine.
i really want duals
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
Chad Speier
Sep 24, 2015 12:32 PM
86White_T/A305
Sep 21, 2015 05:28 PM
