Funny Exhaust Story
Old Nov 12, 2007 | 07:35 PM
bummys_hotrod's Avatar
Car: 84 Z28
Engine: 383
Axle/Gears: 7.5 3.73
Funny Exhaust Story
So i working on fixing up my 84 camaro z28, 355 cid, 700r4. When after bleeding the brakes i was going to take it on a test drive when of course it wont start. So for hours i thought that it was flooded and just need to dry out. So i keep trying to start it over and over using alchool, starting fluid, and tons of gas wearing the battery down and charging it back up. Finally i pull one of the spark plugs out and check if it is wet. But it is dry, then i check to see if it is sparking. Its not. So i look for the obviouse wire loose or something. To no avail. So my only option is that the coil is bad. Even though i never had problems with it before. So i go to pull the old one out and find the missing wire. So i plug it back up and wouldnt you know all the starter fluid, 1 1/2 bottles, achool, and fuel was sitting in the muffler. When i cranked the starter it blew the muffler in half. It was as loud as a cannon. Here are the pictures to prove it. I never laughed so hard in my life. Anyone ever has something like this happen to you.
Attached Thumbnails Funny Exhaust Story-100_0326.jpg   Funny Exhaust Story-100_0324.jpg   Funny Exhaust Story-100_0322.jpg
Old Nov 12, 2007 | 07:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Funny Exhaust Story
very nice!
Old Nov 12, 2007 | 07:49 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
wow! awesome! bet scared the crap out of you. hope the tank is okay. gives you a reason to get a new muffler.
Old Nov 12, 2007 | 07:50 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Nice, bet it scared the hell out of ya!
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Mighty close to the gas tank.... that may have been a bigger secondary explosion...
Raf
Old Nov 12, 2007 | 08:22 PM
Trustin's Avatar
Car: '84 Monte Carlo SS
Engine: BUILT original 305 H.O.
Transmission: 350
Axle/Gears: 373
Believe it or not, several years ago, I was working on my 1984 Monte Carlo SS and had a very similar experience. I had replaced the distributor cap and plug wires and couldn't get the thing to start. I checked all wires, checked cap, and everything (I thought). The Monte has full custom dual exhaust (directly out of the headers into true duals). I just kept pumping and trying and suddenly BLAMMMMM. I blew both mufflers totally apart (just like yours except BOTH OF THEM!). I thought I had been shot and my wife came running out of the house (I was in the attached garage) thinking I was dead.
When I finally settled down, I put the old distributor cap back on (I did find that the new cap was turned about 20 degrees) and the car started right up (really loud of course!!). Had to run to a custom muffler shop to get the car ready for my son's senior prom!!!
Old Nov 12, 2007 | 11:03 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
My buddy had a 87 formula and while he was driving the car backfired and blew the muffler. Said it was loud as hell and scared him pretty good.
Old Nov 12, 2007 | 11:27 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
I hate it when things go boom. If you baby your car, you know exactly what i mean.
Its a good thing i only need one or less mistake to learn.
Old Nov 13, 2007 | 08:33 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Years ago, my electric fan stopped working, so I was just playing with the wires with the key on but engine off, while my date, sitting in the car bored, apparently decided to push my nitrous button. When I got back in and cranked the car over, it blew the mufflers wide open, even worse than yours. Man, it was loud.
TA
Old Nov 13, 2007 | 09:34 PM
fbodyguy86's Avatar
Car: 92 camaro rs
a friend of mine came over once and i was sleeping and didnt hear him knocking or anything so he went to leave very cold our and his mustang (go figure)wouldnt start when it finally did shot flames out the tailpipe a good 3-4 feet and the convertor was on fire flames were coming up the shifter boot and started melting the dash so he came running in the house to get buckets of water and had my sister who just got out of the shower call the fire dept by the time they got there it was all put out then the fireman said " i think its still smoldering get out the 2in hose" my friend was like no its out dont bother then th firemen were looking in the car said it looked like the fire started in the ashtray which was full of butts and ashes but wasnt even burned
BumpaD82
Feb 26, 2016 02:57 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Formula8r89
Sep 22, 2015 04:24 PM
Buggy Disaster
Sep 17, 2015 05:12 PM
Street Lethal
Sep 7, 2015 01:09 PM
