Hooker Super Competition Long tube header(2210) leak at slip tube collector...
Old Nov 27, 2007 | 09:43 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Well, I have had this pesky exhaust leak for quite some time now. The car still runs a little rich, and if I drive it for long distances or idle for a while, the whole car smells like exhaust fumes. After a while, the smell gets in my clothes(which I don't mind but it drives the gf nuts). Anyway, I have narrowed it down to the passenger side header #8 cylinder slip tube. It's not leaking at the flange, but at the point where it physically slips into the main body of the header. I was just curious to see if anyone else has ran into this issue before, and if so what did you do to rectify it? Thanks in advace for any info or suggestions!!!!
Old Nov 27, 2007 | 09:58 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Re: Hooker Super Competition Long tube header(2210) leak at slip tube collector...
Can you say SEARCH????
This has been on the board for a bit. I have seen a couple of threads on this. Here is the current one.
https://www.thirdgen.org/forums/exha...lip-joint.html
Old Nov 27, 2007 | 10:36 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
if you let the car sit for a while then start it does it smell like rotten eggs then its the 02 sensor
Old Nov 28, 2007 | 05:46 AM
paulmoore's Avatar
Actually, I did do a search, but I typed in exhaust leak(which is pretty vague, I know) and went through like 4 or 5 pages of posts and didn't see anything. Then I did a search for #8 slip tube and didn't find anything pertinent. Thank you for the info though, it is most appreciated. I guess I will drop by the parts store and grab me a tube of that stuff and see if it works....
Rayzor32- The car doesn't smell like rotten eggs. Plus, it is a carb'd engine and I don't have any o2 sensors. Plan on putting in 2 wideband A/F's one for each bank so I can monitor my air/fuel ratios.
Old Nov 28, 2007 | 01:15 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I've been running 2210's for at least 7 years. I always coat the #8 tube with the Orange Hi Temp sealant and have never had a problem.
www.geocities.com/dzperf
Old Nov 28, 2007 | 10:59 PM
Comp788's Avatar
I'm lucky my LT headers do not have a slip fit collector. I had a set custom made and they tuck up really nice and no exhaust leaks. They have v-band clamps for collectors.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Street Lethal
Apr 30, 2019 12:14 PM
italiano67
Dec 11, 2016 09:21 AM
tricky1
Aug 23, 2015 01:17 PM
