BEST EXHAUST CUT OUT????
Car: 92 rs camaro
Engine: supercharged 355
Transmission: t-5
Axle/Gears: 342
CAN ANYBODY TELL WHAT IS THE BEST EXHAUST FOR THE MONEY, IVE SEEN SOME ON EBAY JEGS ETC....
THANKS BROS
RAY
THANKS BROS
RAY
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Re: BEST EXHAUST CUT OUT????
I have the quick time performance out of summit. Ive had zero problems. I used the summit 2 1/2inch cutout, with the 3 inch qtp
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
DMHPerformance.com i think the guys name is dave and he makes em custom and he aslso makes a low profile one for ground clearence
ive been looking into this as well and how do you run the wire/where do you run the wire though
then there are some other brands that you might wana check out
qtp,mmccord,DMH,
qtp,mmccord,DMH,
Car: 90RS Conv.
Transmission: th400
after the y I used a straight pipe into the dump,it is a little behind the pass seat.as far as the wiring I drilled a 3/8 hole put alittle rubber grommit in, and ran the wiring under the carpet.I put my switch in the blank under the headlights
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Ive' got the McCord Power Plate on my Z28...I've had zero problems with it. I've got the Quick Time Performance on my Trans Am and it sucks....the motors quits all the time...and I have to hit it with a hammer for it to work....
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
