2 white wires reading same on o2 sensor
Old Dec 27, 2007 | 06:33 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I checked today to find out hich white wire was my hot on the 3 wire o2 sensor. They read the same ohms. I need to hook it all up tomorrow so help is appreciated. I got the sensor from a 91 zr1. The plug it came with has --- a b and c slots. Maybe a certain slot is the hot and the otheer is ground. IDKK. please help
Old Dec 27, 2007 | 10:40 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 2 white wires reading same on o2 sensor
Two wires should be the same color. Those are hot and ground. It doesnt matter which one. One wire goes to a pink and black ignition wire, so it only comes on when the key is on. The other wire goes to a ground on the engine or chassis.
The third wire that is a different color is the signal wire and needs to be plugged into your stock O2 sensor wire.
Old Dec 27, 2007 | 10:48 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
lol i totally searched. I was getting the understanding that one was hot and the other was ground. As in one was only a hot and th other was for only a ground
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
FormulasOnly
Sep 10, 2015 09:07 PM
