Removing cat
Old Jan 22, 2008 | 10:20 AM
Uljas's Avatar
Car: GTA
Engine: 350 tpi
Transmission: th700
Removing cat
Hi my question is when i remove the cat. converter and weld in a straight pipe would i have to use 3 wire 02 sensor or will just a new 1 wire work?And as for the sound level how much will it increase if i just removed the cat and leave everything stock regarding the exhaust?
Thank you wery much
Uljas
PS sorry for my bad English i am Estonian
Old Jan 22, 2008 | 01:22 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Removing cat
i got no cat and a one wire O2, runs fine, a 3 wire is more accurate people say i got a flow 80 and its loud
got a freind with a Z28 that has no cant and stock early style dual Z28 mufflers and its real mellow, just loud enough but not to loud
Old Jan 22, 2008 | 01:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Removing cat
The stock 1 wire sensor will work fine. The O2 sensor doesn't care what happens after it.
Old Jan 22, 2008 | 02:03 PM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
Re: Removing cat
When I removed my cat it really didn't make that much of a difference at idle, but at WOT it made a huge difference. Then again I did add headers at the same time and already have a flowmaster 80 series.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stryker412
Sep 7, 2015 09:11 AM
