I should be receiving them any day now. I'm using the Hypertech HEI dist. cap # 4050. I want to use the MSD 8.5mm wires also. Should I use the short or long wires and what is the best way to keep the wires from coming in contact with the headers? Is there like a wire loom kit or somthing like that available?
i used zip ties to keep my taylor pro wires away from my hedmen longtubes. seems to work well, over a year and wires havent moved at all.
Kevin91Z
close
- Join DateJul 1999
- LocationOrange, SoCal
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1990 Pontiac Trans Am
- Engine355 TPI siamesed runners
- TransmissionTremec T56
- Axle/Gears12-Bolt 3.73
- Liked:26 Times in 22 Posts
Made for You makes a wire loom kit for both Centerbolt and Perimeter bolt valve covers. Its around $50.
89formula350b2l
close
I use the spark plug wire protectors
http://store.summitracing.com/egnsea...=KeywordSearch
