305 to 350 emmissions stuff
Car: 1983 pontiac Trans am ws6
Axle/Gears: ????
do i need to reconnect all the emmisions suff from my 305 to my 350 or can i just leave it with the basics like the smog pump and hosing connecting to it.. basiclly im trying to eliminate alot of the smog crap and block the holes off, i live in california by the way... should i just put it back the way i found it or can i eliminate them?
Axle/Gears: ????
Re: 305 to 350 emmissions stuff
i have a cfi but prolly doesnt make a difference lol yea ill just leave em alone. thnks
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You're in California. You need it all. Assuming of course, that you intend to license the car so that you can use it.
Doesn't matter what CID the motor is. The CFI 350s in Vettes had the same stuff.
Hacking stuff off will give no benefit anyway, toward making power. And on top of THAT, if you build it right, the hood will stay shut, and it won't even matter what's under there. Don't worry about it, just put it back like it belongs, and life will be good.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you show up to our meeting Saturday, we'll show you all the SoCal cars we have that run 12 second ET's, get 25+ miles per gallon, and pass CA's smog test as clean as stock. Its not that difficult.
