View Poll Results: Which exhaust route do I go?
Multiple Choice Poll. Voters: 4. You may not vote on this poll
Another exhaust question
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
I've given up trying to find a local place to fab up my true duals...at least for a reasonable price. Keep in mind I am having Hedman Longtubes installed when I do this.
Now I want to either have a custom exhaust y pipe with dual cut outs and keep the 3" Magnaflow catback OR buy the mufflex 3.5" pipe and get the hooker aerochamber (I love the sound of those) I am expecting to be 380 rwhp and 400 torque to the wheels with the xr276 cam and somewhere around 420rwhp and 440 torque to the wheels with the xr288 cam.
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Another exhaust question
So I have found a fairly cheap solution to your problem. What I am thinking of doing would be a set of 1 3/4 with 3 inch collector shorties with a 3 inch cat back. Take the cat out. And where the cat was I would put a cut out for the strip to utilize more flow and power. This whole set would only cost 400 dollars and would have no ground clearance issues. The nice thing when your at the strip with the cut out you would have enough flow for 500 horse. Let me know what you think, because I am thinking of doing this
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
If you are stuck on long tubes, then custom y-pipe it and hook it to your current system. I am a BIG believer in 1 3/4" SLP (or Dyno Don) shorty headers with a custom y and 3" cat back for the majority of setups on our cars...
Car: 1988 Camaro
Engine: 383 Stroker
I believe in that system to. One thing that i did just find that Dougs make 1 3/4 headers with a 3 inch collector. Dyno Dons only have a 2.5 collector. With this and a 3 inch y and 3 inch the whole way through would be the way to go. If that's not enough put a cheap cut out for the strip. Saves money and has no clearance issues!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Car: 1988 Camaro
Engine: 383 Stroker
Check jegs website. Dougs do make shorties 1 3/4 with 3 inch collector.I also checked dougs catalog and they both conflict with each other. I hope jegs is right, because that would work perfect for me. To confusing Here is the part # 776-D3320-R
Check it out captain
