305to 350
Old Mar 17, 2008 | 12:58 AM
one wheel peel's Avatar
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
305to 350
doing a swap from a 84 305 to a 72 chevy 350,now the stock exhaust manifold on pass side is causing a prob ,the back bolt hole does not line up? driver side did just fine.help
Old Mar 18, 2008 | 10:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
3rd gen exhaust manifolds use a "7th" bolt hole on that back bolt. Earlier heads didn't have it.
Odds are about 100:1 that your 305 heads are better for that 350 than the heads that came on it. Best options are (in ascending order): 1) Put on headers; 2) put the 305 heads on the 350; 3) put the 305 heads on the 350 and install headers.
Old Mar 19, 2008 | 05:48 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Re: 305to 350
Worst case scenario, just run it. If the manifold is flat it probably won't leak. I wouldn't go to the trouble of putting 1.8x valved heads on a 350
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
