Dyno Don Headers Fitment
Old Mar 17, 2008 | 05:23 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Looking at getting Dyno Don's headers, and I wanted people who actually have them and installed them inform me of how long it took and if there were any issues when installing them? thanks alot
Old Mar 17, 2008 | 11:51 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Dyno Don Headers Fitment
They're no worse than any other headers as far as installation, but they fit a lot better. It should take a day or two to install them, depending on how fast you are and how hard it is to remove the old manifolds.
Old Jun 7, 2008 | 10:57 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
I am having an issue clearing the a/c condensor/ heater box. Anyone else have this problem?
Old Jun 7, 2008 | 11:55 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
No. Mine clear everything just fine.
Old Jun 8, 2008 | 06:35 AM
BCdawg57's Avatar
hmm...i think it must be the gaskets im using cause on a dry fit, they fit fine. but with the gaskets in there, the earls gaskets, which are pretty thick, i have just a little bit of a clearing issue. should i be wary of cutting into it about 1/4 of an inch?
Old Jun 8, 2008 | 03:13 PM
Car: 1989 GTA
Engine: 369 TPI
Interesting. I'm also using the Earl's gaskets with no problems. Don also recommends the Earls gaskets and uses them quite often if the customer does not already have a set.
Not that this applys to anyone's car inparticular but I wonder if soft motor mounts or maybe a car that has been in a crash is causing some of these fitment problems. Maybe polyurethane motor mounts will cause a motor to sit a little higher.
I have seen a few of Dyno Don's headers on 3rd gens and there is plenty of room. Just wondering what the variables might be to cause these issues from one car to the next.
Old Jun 8, 2008 | 03:39 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
I'm also using Don's headers with Earl's gaskets and have no fitment issues on my '83 TA.
Old Jun 8, 2008 | 05:02 PM
BCdawg57's Avatar
The car hasnt been in any accident that would disfigure the car to that extent. I did however just install poly motor mounts with my lt1 swap...maybe thats the problem?
Assuming you kow where im talking about, (the lower portion of the black box in the passenger side of the engine bay). Is there anything i should worry about while trying to make clearance? Is it something i should remove in order to prevent damage to anything on the inside?
Old Jun 8, 2008 | 08:29 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
I'm waiting on a set of Don's headers, so I can't comment on fitment yet.
I don't know about cutting into the A/C box. Any opening you made in it would need to be closed up, and you would have to be careful to not cut into the evaporator, which I think would be closest to the spot you are talking about.
If you don't need A/C you could install a non-A/C heater box, which would give you more room. If it were me and I wanted to keep my A/C, I'd probably swap out the poly mounts for some new rubber ones.
Oh, and the plastic (or maybe fiberglass?) on the A/C boxes is kind of brittle, so keep that in mind if you do cut into it.
Old Jun 13, 2008 | 11:39 AM
BCdawg57's Avatar
I replaced my mounts with rubber and it looks like it has resolved my problem.
Thanks guys.
MustangBeater20
Oct 29, 2022 09:20 PM
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
1984HO
Mar 19, 2021 11:59 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
kah992
Aug 19, 2015 02:55 PM
