Exhaust shop...
Old Mar 30, 2008 | 06:13 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
Exhaust shop...
I am wondering if i can put on my punched out cat and send it to an exhaust shop to get the rest put on? Will they say anything about the cat being punched out... i've heard both sides of the story so idk. WHat do you guys think?
Old Mar 30, 2008 | 06:39 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Re: Exhaust shop...
Well last year I couldn't find a single shop that would put on an exhaust without having the cats on. All of the shops I called were either national chains or bigger locally owned shops. Well I finally asked around enough and found a small auto repair shop who did exhaust as well. They did a pretty decent job considering the amount I paid. My X pipe and mufflers hang a little low but I can live with it.
Old Mar 30, 2008 | 07:48 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Re: Exhaust shop...
Your location is an emissions state. You might have a hard time getting an exhaust shop to work on your car "on the books".
Old Mar 30, 2008 | 09:18 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Exhaust shop...
what about backpressure? i bought a cheap high flow cat its only about a foot long. Will it affect my hp much or no? if i look i can see through it a little....
Old Mar 31, 2008 | 10:33 AM
Pukka's Avatar
Re: Exhaust shop...
What about backpressure? Read the sticky on this subject.
A high flow cat may get you another couple of hp. You have to re-do the entire exhaust to really see a difference.
Old Apr 3, 2008 | 05:37 PM
v10viper04's Avatar
Engine: LT1, L99
Re: Exhaust shop...
Do you mean opposed to a standard cat?
Old Apr 3, 2008 | 09:58 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
Re: Exhaust shop...
The answer is it depends on the shop. I don't think they can really be pinned for working on a car with a gutted cat... as in they can probably do a cat back for you with no legal reprocussions. The inspeciton is only visual, so a gutted cat will pass inspection (assuming you're not in the NYC area where they would put your car on the sniffer).
That's the only thing that can make sense... because a straight pipe will be most efficient, follwed by high flow cats then OEM cats.
IMO High flow cats are the way to go, they only really steal maybe 1-2 Hp compared to a straight pipe. The backpressure caused by a cat is minimal and probably won't effect your powerband.
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
