Hooker or headman lt's?
Old Apr 5, 2008 | 11:31 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
i currently have hooker 2210 lt's on my z, w/ a zz4 hsr &t56. i have a chance to pick up some headman lt's for 100 bucks. they are the 1 5/8, so they have smaller primaries than the hookers at 1 3/4. they are both non coated, but i'd really like extra clearance w/ the headmans, so i can lower the car 1.5". what kind of performance loss will i see by switching from the hookers to the headmans? i have a 2.5" y, w/ 2 high flow cats, to a 3" single exhaust after the headers btw, but i want duals in the future....
Old Apr 5, 2008 | 03:52 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: Hooker or headman lt's?
I say keep the Hooker LT's. IMO it would be a real PITA to redo your whole exhaust. I would kill to get ahold of the Hooker 1 3/4 LT's.
On the other hand, I dont imagine it would be much of a performance difference going from 1 3/4 LT to 1 5/8 LT. I think I actually saw a dyno test somewhere on a 500 flywheel horsepower engine and he switched from hedman 1 5/8 LT to the hooker 1 3/4 and lost 10 horsepower and 20 ftlbs of torque. ill search the web again for the article.
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
You will most likely see a small GAIN on the bottom end from the smaller primary. However the setup you have now will have to be modified to get that y-pipe to work, so you may as well do the duels now.
Headers are not the low point in the system anyway-----either of those will be good for a 1.5" drop----the low point is gonna be at the trans x-member.
Old Apr 5, 2008 | 10:22 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
Axle/Gears: fact G80 with GT4 3.73
i agree with Mrbrooks. u will get a small torq gain.
i am in the process of doing duals on my 84 t/a. i chose the hedmans. i just thought that 1 3/4 was to big even after i do the motor swap. not mention clearences in the motor compartment.
Old Apr 6, 2008 | 08:49 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
stay away from 1 3/4 header unless your going to do a lot of track time or your going to be making serius hp. 1 5/8 headers are good for any street car. i have headman lt 68468 and I have no complaints.
Old Apr 7, 2008 | 12:44 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
the hookers on there now are NOT got for a drop at all, 3.5 inches of clearance as they are now, and they are just as low as the x-member and exhaust by the x-member.
Old Apr 7, 2008 | 03:50 AM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
They should'nt hang any lower than you're subframe. The pipe will have to dive under the x-member to clear. That is usually the low point in a long tube system.
Old Apr 7, 2008 | 07:45 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
http://s272.photobucket.com/albums/j...186548/Camaro/ there is a pic of the exhaust, maybe im missing something. the collecters are only 3.5 inches of the ground, so w/ sportlines they'd be 2 inchs right? thats scary low to daylie drive. how woud i run duals w/ my set up? i was thinking oval pipe fo rclearance, and going around the x-member, but more linearly than what i have now, the guy b4 me kinda did a hack job on the y pipe....
Old Apr 7, 2008 | 08:01 AM
carscomefirst's Avatar
Car: 04 gtp, 96 f150, 88 camaro
Engine: 3.8sc, 5.0, 385ci
Transmission: auto, 5speed, 700r4
Not having headers myself, I dont know which ones would be be better for your application. however, I might be interested in buying the ones you dont use. PM me if interested. thanks
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
