do i need new headers?
Old Apr 17, 2008 | 06:05 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i have the edelbrock tes headers on there now. they are about 4 years old. well my problem is that the pass. side header always has a leak in the back. i will replace the gasket tighten them all down and check them everyday for the next week. it is fine for awhile then they burn through again. i think they are warped or something. is it possible to fix them if they are warped? like mill it down? forgot to mention. i have even used the allum. ones and it still leaked with those on. also the trick flows that i have are the d-port exhaust version
if not, then what would be a good set of headers that have a y-pipe? the roads here are crap so i can't do longtubes because of the clerance. thanks for the advice.
Old Apr 17, 2008 | 09:09 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: do i need new headers?
I had the same prob with my edelbrock tes on the driver side. What I did is called summit and ordered the thickest gasket there was, and tightened the header as much as I could.
Old Apr 18, 2008 | 01:55 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, the Edelbrock headers are crap. Get yourself a set of Dyno Don's headers. Search this board for "dyno don headers" and you'll see.
Old Apr 18, 2008 | 11:11 AM
Travis odell's Avatar
Car: 89 chevy camaro rs
Engine: Tbi 305
Axle/Gears: 3:73s
Dyno Don's? Heres a little peice of advice get you a set 2055s hookers that you been longing for and thank me later.
Old Apr 18, 2008 | 11:48 AM
yeah i am talking to him right now through pm's
yeah those are a little out of my price range.. ok more than a little
Last edited by 91 camaro racer; Apr 18, 2008 at 11:49 AM. Reason: Automerged Doublepost
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
