true duals w/ shorties
Old May 3, 2008 | 07:45 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
So can it be done? Right now I have a set of SLP's and whenever I drop my motor in its going to need exahust to be done. Not sure if I should run single 3" or dual 2.5 or 3". Going to go with dynomax bullets probably, no cats. My neighbor said his exhaust guy could do it, im just wondering because I read all this stuff on here about how we cant have dual exhaust on our cars im just wonder what the big deal is. it seems like you could easily run dual pipes straight back w/o losing too much clearance on a non lowered car.
Old May 4, 2008 | 09:30 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: true duals w/ shorties
I recently put up a thread about running true duals in the factory location. My plan was to buy two Dynomax 2.5" intermediate pipes and get a Dynomax universal tailpipe (make sure its long enough) and connect to a single dual 2.5"in/2.5"out Magnaflow muffler. However, I stole this idea from ZNuclearZ. https://www.thirdgen.org/forums/exha...html?highlight=
i think it would be cheaper and easier to do yourself.
for simplicity, i would go single 3" though. How much horsepower are you putting out? Are you running nitrous?
Old May 4, 2008 | 09:40 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Anyone know what the outlet size is one SLP headers? I think the hardest part would be flanging it up to the SLP's and using some sort of mandrel bend pipe to come down flush with the underbody, then pretty much you could put an x pipe, then run the exhaust straight down the driveshaft, put two bullets before the axel then get some tail pipes later
Old May 4, 2008 | 10:36 AM
Car: 92 Camaro
Axle/Gears: S60 373
the outlet is 2.25 the flange is the stock two bolt flange. In other words, it can bolt up to the stock y pipe until you bring it to a place that can bend pipes for you.
Old May 4, 2008 | 11:30 AM
JimmyDavidson's Avatar
Car: 1984 Camaro z28/SC
Engine: 355
Axle/Gears: 9bolt 3.89
With shorties, the only problem area I can see would be on the driver's side, and the clearance of the brace above the panhard bar. I saw one guy cut his up. But you might be able to use oval pipe to go through there, or you could modify the brace and but a U for clearance for the pipes, or you could just run both pipes over the passenger side, but I dont like that idea cause one pipe would be longer than the other, and I like the pipes to go straight back, with minimal bends.
I'm going with duals and I be trying out those options later on this year. I'll probably use a combination of oval pipe and the U-bend, unless I can just get away with the oval pipe.
Old May 5, 2008 | 01:44 PM
skidude's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7 TPI, L98
Axle/Gears: 3.42:1
Check this link:
https://www.thirdgen.org/forums/exha...exhaust-3.html
then go down to post 122 & 123
I've got SLP's on mine with true duals. I snagged a pair of late model cats and ran 2.5" all the way. Have a look at the rear. You don't have to go over the axle. I've never had any problems with mine going under the axle. By the way, the cats went to the taxidermist first. They are there, but they don't meow anymore.
Old May 5, 2008 | 02:45 PM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
I did 2.5" true duals on the BlueZ() on Heddman Shorty headers. The biggest hassle was the two collectors on the headers angled in towards each other(for a Y-pipe), so the true dual piping had to come from the collector and immediately out and way from one another... wasn't much room to do this. From there, the piping ran down the factory exhaust tunnel under the car.
Clearance was hindered a little bit, I dumped the exhaust at the rear axle with Dynomax Bullet's. Was I happy with it? Eh... I was iffy on it. The new owner immediately took the exhaust out and re-did it with a Y-Pipe.
hookin88formula
Dec 2, 2002 11:58 AM
CarNDrvr
Sep 1, 2001 08:03 AM
crazeinc
Oct 18, 2000 12:19 PM
