Third Gen Dual Exhaust Picture Collection
Car: 1987 camaro
Engine: 358
Transmission: TH350
Hey mw66nova....how hard was it to make that exhaust? Did you have to make any bends? Could you get some more pics of your exhaust I am very interested in doing the same setup.
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
exhaust
Just got my new exhaust.
Cost me 180 Bucks installed
3'' pipe from cat
Huge Magnaflow
Dual 2 3/4'' tips from muffler
3'' pipe from cat
Huge Magnaflow
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
any probs when running dual out both sides in front of the rear tires? is it possible to run the drivers side pipe down the drivers side of the car?
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
Originally posted by greezemonkey
had to add the rest.....
In the picture of your car up on the 2 post lift- it looks like your hedders would make gettin your oil filter out a pain in the ***- is it?- AND is your H/x pipe efficient?
Car: 1982 Pontiac Trans Am
Engine: 383 stroker 4 bolt roller, juiced
Transmission: b&M th400
Axle/Gears: 4.10 with c-clip elims
i just got a question for the guys already running true dual... right now i have true dual on mine its a headmen setup down the stock exhaust channel.. i just have the clamps welded together and up tight to the body as best i can... doesnt hang to low.. its 2 1/2 all the way back now i just tossed in a new block from a 355 to a 383 i have the stuff to change it over to 3 inch besides the headers themself but will i really need it? im already plannign on swapping out the mufflers for somethign nicer higher flow with cut outs... but would going that 1/2 inch all the way back do me any good? or just a waste of time
as you can see my mufflers are tight together and acctually vibrate pretty bad at higher RPM i plan on switching them out and putting the mufflers in the little space between the trunk and wheel well on each side..
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Oil filter is not that bad, I seen worse on front wheel drive cars..I usually let it cool a bit before attempting oil filter replacement. And yes the "cross over" pipe does work, the exhaust was not linked when I first installed it and it was somewhat raspy...after I put the connection in there it smoothed right out.
Car: 07 Trailblazer SS
Engine: 6.0 LS2
Transmission: 4spd auto
Axle/Gears: AWD w/4.10's
thats exactly the way mine is but im trying to find a decnt muffler to run them seperate out the back... i dont like them ontop of eachother like that they rattle too bad, im thinking about getting the warlock muffler with the cutout built into it so with 3 wing nuts taken out your runing straight pipes, but im not sure if they will fit up and down in the small space between the trunk and wheel wells... i could always use a glass pack or somethign smaller but id rather not anyone try that yet?
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
anyone go around spohns trans crossmember? ive got long tubes and the spohn xmember and t/a.... looking for some ideas
Car: 87 Camaro IROC Z-28
Engine: 1976 chevy 350 far from stock
Transmission: stock tranny
i currently have pretty much the same thing, true dual 2.5inch and moroso spiral flows at the back and an x-pipe. those spiral flows sound damn good, cost me 800 dolalrs to get it done, but i put the headers in myself, or else it would of been over a grand.
Car: 1989 Iroc Z L98
Originally Posted by shaddow_wolf
here are mine got them done this last weekend I WENT AND FINALLY GOT THE TAIL PIPES PUT ON YESTERDAY.
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7 TPI, L98
Axle/Gears: 3.42:1
Axle/Gears: 3.42:1
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Cheap and fairly simple, got it done in one afternoon and it gets the cops off my back!
Car: 84 Z28, 89 RS, 98 SS
Engine: 350 .060 over, 350 .040 over, LS1
Transmission: TH350, TH700r4, T56
Axle/Gears: 4.11 spool, 3.73 open, 3.42 posi
Are you using the stock transmission crossmember i can't tell from the pic's.
Are you using the stock transmission crossmember i can't tell from the pic's of the white 85 z28
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
well I finally finished mine and I can say that I am impressed. I have 4" of ground clearance although it doesn't look like it in the pics because the car is on carpet.
Car: 1986 IROC Z-28
LOVE THE TRAILER HITCH!!!!!!!!!!!!!
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Originally Posted by 88IROC350TPI
UPDATED 5-19-2006
82-92 f-body dual exhaust systems
After a long time of the original picture collection being down I've finally put it up again. I'll be adding more pictures and redoing it all pretty soon ...I'm kinda lazy though.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
watsup guys. i got a true 2.5 inch dual system. its exits out infront of the rear tires on both sides. it has car chemistry race mufflers. not exactly the quietest mufflers but they are quieter than straight headers. here's a side shot for those of you that wanna see. looks like a 2 inch but its 2.5
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
Hooker Super Comps with custom hedman s tensions and flowmaster delta force race mufflers. I have about 3.5" of clearance at the s tension and 4" at the mufflers.
Car: '86 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: standard 3.23
I'm going with the minimum amount of components to make it cool... 3" to 2 1/2" collector reducers, 2 1/2" summit cutouts, flowmaster 40 series mufflers, all welded to each other in that order... no pipes, just 3 components welded together. Short and simple
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
just my 2 cents, but i have always had the understanding that a single 3" pipe will outflow 2 - 2 1/2 pipes anyday, saves you a lot of headaces, but i did have duels on my car once and it definatly had a different sound to it.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
dual 2.5" will outflow single 3.5" exhaust
think back to grade school with how to figure out area of a circle and do that to figure out the available area within a circle.
im lookin to do a true dual exhaust on my 85 iroc and i was wonderin how much urs came out to. i was plannin on gettin new headers, then no cats or just hollowed out, i kno its risky but im willin to risk it wit the cops lol.
Dual Exhaust
Hi,
I have seen many pics here with dual exhaust running straight to mufflers and not many using the x pipe, would someone explain the benefit of the x pipe versus running right to the mufflers. I know of a setup (no pics) of single exhaust to dual tips using a dynomax bullet muffler on a six speed 4th gen thats sounds awesome and super load but quiet at idle, all 3 inch pipe. So for those who have 305ci and want the performance and sound but don't want dual setup just fab a nice 2.5 inch mandrel system with dynomax bullet muffler and it will be a screamer.
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
here is my true dual exhaust pics click the link 9-10 pics tons of clearance too
http://newengland-motorsports.com/fo...767#post344767
Car: 82 Trans AM
Transmission: th350 turbo
love the exhaust setups on here. on the first page with the white camaro is how i plan to do my exhaust. im going to use shorty or long tube headers with a t5 transmission that i will be swapping in here soon. and above 2 post from mine, have you actually heard the dynomax bullet mufflers? i planned on getting two 3" inch mufflers for my TA. i was just curious but thats the mufflers i want.
Car: 87 IROC-Z
Engine: 355 carb'd
Just wanted to add a pic of my new true dual exhaust...... IMCO mufflers, flowmaster h-pipe, and new hedman hedders.....if I could figure out how to do a sound clip I would.....sounds AMAZING and wow what a difference in the feel of power compared to the stock exhaust and edelbrock headers!
Car: 90 Camaro RS
Engine: 305 TBI
Hooker 1 3/4 LT's with 2.5 tubing and 3" Dynomax bullet mufflers
More pictures by clicking me
Car: 86 IROC
Engine: 383
Axle/Gears: 3.54 Dana 44 IRS
it was an option that year
