Third Gen Dual Exhaust Picture Collection
Old Mar 21, 2007 | 08:54 PM
  #151
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: Third Gen Dual Exhaust Picture Collection
pretty nice setup, i used magnaflow mufflers too but mine goes all the way back even over the axle and the mufflers are at the way back of the car
Old Mar 21, 2007 | 09:56 PM
  #152
87z289's Avatar
hey, i just got a 350 ram jet dropped in about 4 months ago and i have the stock exhaust i have hedman headers and then 2 1/2 inch single exhaust one cat and a flowmaster muffler....im looking for a way to run true duals but still have 2 cats so i can pass inspection....any ideas?
Old Apr 10, 2007 | 06:51 AM
  #153
85irocz355tpi's Avatar
Car: 85 IROC-Z
Engine: 355 TPI
Transmission: 700R4w/Shift Kit
Axle/Gears: B/W 9 Bolt-3.45
Check this out it's been on the car for about 4 years with little problem. As long as you have good shocks and struts you should be fine. I hope that works right. I'll see if i can get a better picture under the car for you.
Old Apr 10, 2007 | 05:02 PM
  #154
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Is your car leaning or is it just because of the grass?
Old Apr 10, 2007 | 06:04 PM
  #155
Car: 85 IROC-Z
Engine: 355 TPI
It's cause of the grass.
Old May 20, 2007 | 02:13 PM
  #156
Mustang Crusher's Avatar
Car: 89 Camaro RS
3 inch Flowmaster cat-back, Magnaflow high flow cat, Pacesetter Headers, 3 1\2 inch tail pipes
Old Jul 29, 2007 | 07:26 AM
  #157
paul1992's Avatar
aight, i have a 1982 camaro z-28, it had a 305 with crossfire injection, i took that out and dropped in a 355, i have hooker competition shortie headers, the problem is, i cannot bend the 2.25" exhaust pipe tight enough from the reducers so that they go to the side and run parallel with the body of the car, i have purple horny mufflers and i want each pipe to exit in front of the rear wheels. any suggestions are welcome, pics of different set-ups with these headers would be awesome!
Old Sep 4, 2007 | 09:52 PM
  #158
josh3049's Avatar
Car: stk 83 z28---84 rs
Engine: 305 cfi-----355 carb
Transmission: 700r4-----t-5
Axle/Gears: stk-----4.30
summit sells a kit that will run you to the side all the way back over the axle and out the back. granted they both come out on the same side in the rear but it sounds pretty sweet. I think you can see where they exit in my pic. Kit was only like 150 dollars.
Old Oct 28, 2007 | 09:53 AM
  #159
matrix99's Avatar
Re: Dual exhaust picture collection ***HELP RE-READ***
i have an 88 iroc i wana put a tru dual exhauts on it but everybody tells me i can't because theres no room and a cold air intake please help me im sure there is a way i can do it if you have any suggestions write back
Old Nov 6, 2007 | 01:26 PM
  #160
Fast3rdGen's Avatar
LOL.....my old 84 TA dual exhaust is in those pics and I see several cars now using that set-up here. Funny......everyone here said it was a bad idea back when I did it.
Old Nov 13, 2007 | 02:40 PM
  #161
gtracer9's Avatar
Car: 1988 Chevy Camaro IROC-Z
Engine: 5.7 350ci TPI
Transmission: 700R4 for now. Soon to beT-56
Axle/Gears: Stock. Goin to swap for discs soon.
I ran duals on my 88 and the only problem I ever ran into was clearance. I lived in Phoenix, AZ for awhile and the speed bumps can kill your exhaust. I crushed some sections of the exhaust a few times. It sounded great and looked ok though. I had Hedmann short tube headers, ran the tubing back to just behind the front seats with Flowmaster's on each side and just dumped it out the end of the muffler.
Old Nov 27, 2007 | 10:28 AM
  #162
EndlessSummer85's Avatar
Car: 1982, 2000 Trans Am
Engine: 350 bored .040 over: LS1
Transmission: Borg Warner Super T-10: Tremec T-56
Axle/Gears: 4.10s; 3.42's
Does anyone have any pics of ideas of running true duels with SFC??? I have comp engineering sfc in and it's a pain to get any exhaust to fit right I have hooker on right now, but it has a real ugly y pipe coming off hooker shorty's. I want to get hedman LT's and run true duels any suggestions??? Or pics of routing with SFC...
Thanks!
Old Dec 4, 2007 | 04:36 PM
  #163
Anyone??
Old Dec 7, 2007 | 10:23 AM
  #164
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Axle/Gears: 3.54 Dana 44 IRS
Originally Posted by EndlessSummer85
Anyone??
go back to page 3 of this thread and look at my setup. I have SFCs.
Old Dec 7, 2007 | 11:11 AM
  #165
Looks pretty good, any fitment problems w/ the 2210's??? Every lt's i find say they won't work with a standard tranny. I have a t-10 w/ mech linkage so I might have to stay with shorty's... My SFC's are a little different than yours though... But I think I can tuck the exhaust in...
Old Dec 7, 2007 | 12:25 PM
  #166
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
the 2210's should be fine with the t10, i know they clear t5's and t56's without a problem.
Old Dec 8, 2007 | 11:48 AM
  #167
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
he has mechanical clutch linkage though, so that might be a problem...
Old Dec 8, 2007 | 11:59 AM
  #168
mw66nova's Avatar
Engine: 7.0L
well, alls i can say is "you gotta pay to play". if he wants to run a t10 and longtubes, modifications may be required. that's kind of part of hotrodding...bolt on's never are
Old Dec 9, 2007 | 04:43 PM
  #169
Yea that's exactly what I'm worried about. I'm thinking about going a dif route now. Hooker is finally makeing a y-pipe for the headers I have. Thinking of getting that even though it's like 240 bucks and running a 3'' classic chambered muffler, then a short pipe and a dump before the axles. There's another car running pretty much the same thing on here and it sounds pretty mean. With my cam it should sound a lot better than the hooker catback I have, way to mellow.
Old Dec 24, 2007 | 08:17 AM
  #170
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Here is my 3" to 2 1/2" exhaust. The 3" was made from mandrel bends which were cut and formed together. After the X pipe they reduce to 2 1/2 and are taken side by side over the axle. In the back it is ran with magnaflows kind like a vette is with muffler location.
Attached Thumbnails Third Gen Dual Exhaust Picture Collection-07_21_07_1037.jpg
Old Dec 24, 2007 | 06:04 PM
  #171
nice ride.
Old Dec 29, 2007 | 01:33 AM
  #172
Sinz86IrocBlk's Avatar
Car: 1988 IROC-Z
Engine: LB9
Wow your car is my new inspiration!
Old Jan 23, 2008 | 10:39 AM
  #173
Captain Nguyen's Avatar
This picture is not mine.
I have found this picture at other forums.
It's a Dual H-Pipe exhaust.
Part 1
Part 2
Old Jan 23, 2008 | 03:44 PM
  #174
ssean92's Avatar
Car: sold
I look at these exhausts and Why????? you can get just as much flow out of a single exhaust and have alot mor ground clearance, and you dont see it form the side of the car.....Just my 2 cents
Old Jan 30, 2008 | 01:51 PM
  #175
Well....
This is my setup dual exhaust.
Old Feb 2, 2008 | 07:29 PM
  #176
Dee555's Avatar
Car: 89 Iroc - 84 Trans Am -84 Corvette
Engine: 350 TunedPort
Transmission: 700R/T-5 World Class
Axle/Gears: Posi/Ausi/Disc/3.08
Did you have to reroute fuel lines to do the dual exhaust on your car?
Old Feb 2, 2008 | 08:09 PM
  #177
Nope,
Must I do this?
Old Feb 3, 2008 | 06:20 AM
  #178
Dee555's Avatar
all depends how close you are do you have a picture?
Old Feb 4, 2008 | 08:51 PM
  #179
dark_daku89's Avatar
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
here is my 2.5 inch true dual exhaust setup on my rusty 92 RS.
From Headers
Going in stock location
and finally going over the axle
and muffler
Old Feb 4, 2008 | 10:55 PM
  #180
Dee555's Avatar
Thanks for your time and the awesome pictures.
Old Feb 4, 2008 | 11:15 PM
  #181
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
very nice
Old Feb 11, 2008 | 12:07 AM
  #182
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Here are a few of mine
Attached Thumbnails Third Gen Dual Exhaust Picture Collection-duals1.jpg   Third Gen Dual Exhaust Picture Collection-duals2.jpg   Third Gen Dual Exhaust Picture Collection-duals3.jpg
Old Feb 11, 2008 | 01:55 AM
  #183
Dee555's Avatar
how did you support them, do you have pictures of them from the rear?
Old Mar 12, 2008 | 02:57 PM
  #184
87z289's Avatar
hey guys, i got a huge question... well a few... i have an 87 berlinetta camaro originally with a 2.8 6 banger... swapped the motor trans n rear out with a rebuilt 700r4 with a shift kit.... 3:73 posi and a ram jet 350 with 350hp and 400 tq... i have a hedman shortys with a y pipe and single exhaust with dual outlet 2.5'... i wanna put duals on it but like i have seen in the pics some ppl run it down the middle by the drive shaft... yet i dont think theres room on my car for that and on the driver side there isnt like a cut out in the floor or anything i could run a pipe there but im not sure if it would bottom out... i have really stiff springs in the front so idk... and then i saw it ran on the passanger side with 2 pipes... would it work on the berlinetta model? this is killing me... i took it to meineke and they were like ya cant put true duals on and i just walked out...
second question: feels like my motor is restricted and doesnt actually have 350hp and i have no clue why.... one shop said it could be the wiring but there are only like 6 wires from the ecu and three of them go to nothing but it runs smooth but jus feels restricted and has really shitty gas milege... and the tranny shifts at like 4100 when you dont shift by yourself... any ideas? im lost... and i was thinking about a supercharger and then ppl siad i cnt cuz its only a 2 bolt main but i figured i could run like 6psi... someone help me out plz... thanks
Old Mar 14, 2008 | 09:25 AM
  #185
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
what are the best type of hangers to use and where's the best place on the under body to hang the duals from?? frame rails???
Old Mar 27, 2008 | 05:23 PM
  #186
redcattaro's Avatar
Car: '84 Z28, '86 IROC
Engine: 305, 406
Transmission: T5, Super T10
Axle/Gears: 3.23, 4.10 Posi
why don't more people use the dynomax dual kit? or at least buy the kit, get someone to bend 2 1/2's like the kit, then return the kit? i run the dynomax kit, which is dual 2 1/4's. i run summit shorty headers and thrush 2-chamber mufflers. it sounds pretty good for a pretty much stock 305 and has pretty good ground clearance. actually better ground clearance than my stock single exhaust.
Old Mar 31, 2008 | 11:08 PM
  #187
MedVader's Avatar
Car: 90 Formula hardtop
Engine: 5.0 TPI
Is that the 89009 kit?
The pictures I've seen show that it is NOT mandrel bent. Is that true?
It's pretty cheap $163 at Summit. I'm thinking about buying this.
Old Apr 1, 2008 | 12:17 PM
  #188
redcattaro's Avatar
Engine: 305, 406
yea, that's it. it is compression bent but if you are really runnin that much horsepower where you need it not to be compression bent you could get someone to bend a system using that as a model. i think it's a pretty good system although it was a little tough gettin it on. but make sure you use the headers for that system. i didn't and i had to modify it because my headers didn't have the same angle as the headers you are supposed to use. it's pretty cheap though so i figured "what the heck" it can't be worse than the exhaust i had before. sound's good even with my 305
Old Apr 12, 2008 | 02:03 AM
  #189
stevo the torpe's Avatar
Car: 91 maro
Axle/Gears: 373 locker
how do the packs sound?
Originally Posted by 84z28350
Cheap and fairly simple, got it done in one afternoon and it gets the cops off my back!
Old Apr 13, 2008 | 01:36 AM
  #190
Car: 91 maro
i guess i killed it huh?i think they sound good allthough i dont no what they would sound like with a 383 and 450+horseess iam just starting my exhaust as all of u that put true duals and had them made u notice u have to drop down 2-3inch to clear crossmember.
Old Apr 25, 2008 | 11:47 PM
  #191
Car: 85 IROC-Z
Engine: 355 TPI
I finally got some pics from underneath the car. Remember that everything except the mufflers have been on the car for 5 years now. The only thing I have done to it is replace collector gaskets about 500 times and replaced both reducers. In the process of doing that I brought the front of the passenger pipe closer to the floor which would have been a big help before I replaced the front struts. But anywho. Let me know what ya think.Third Gen Dual Exhaust Picture Collection-sd530857.jpg
Old Apr 25, 2008 | 11:50 PM
  #192
Car: 85 IROC-Z
Engine: 355 TPI
here's one more from the back. I know the mufflers I tucked up pretty far to were the muffler's exit is hitting the axle but there's not a whole lot of room under our cars so it'll have to do for now.Third Gen Dual Exhaust Picture Collection-sd530862.jpg
Old May 13, 2008 | 10:53 AM
  #193
SteelTownMadDog's Avatar
At 2x 2-1/4", the flow area is more than a single 3" exhaust so it's not bad. A 3" exhaust currently handles my current 375HP pretty good.
You said it was a pain to get on. What exactly was the problem? Bad fitment?
Old May 16, 2008 | 02:39 AM
  #194
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Dee555, I welded on the hangers, and connected them with a long bolt I ran through the seat belt screw hole.
Old Jun 3, 2008 | 10:51 PM
  #195
skinny z's Avatar
This is a Hedman entry level header ( 1/4 " flange and 18 gauge tubing) with collectors reduced to 2 1/2". Stainless mandrel bends cut to fit and then to a flowmaster stainless merge pipe. A Flowmaster 3" aluminized (from a cat back system) goes over the axle into the muffler and a single 3" tailpipe.
Attached Thumbnails Third Gen Dual Exhaust Picture Collection-100_1920.jpg   Third Gen Dual Exhaust Picture Collection-100_1921.jpg
Old Jun 6, 2008 | 08:25 PM
  #196
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
thats a decent looking setup! got any ground clearance pics?
Old Jul 4, 2008 | 01:03 AM
  #197
Thug Life's Avatar
the headers is so close to the starter are there any issues about this? because I got the same headers that you got,guys Im thinking of doin my 92 Z28 dual exhaust and I really dont know which mufflers to get I want something Loud louder than SLP's I will put X pipe and two mufflers and turndowns
Old Jul 16, 2008 | 12:10 AM
  #198
chattersonm's Avatar
Car: 1986 camaro sport coupe
Engine: 2.8 v6 MPFI
Transmission: LB8
Axle/Gears: 2HH 3.42:1
lol, can anyone give me some advice on what i should do to a 1986 camaro sport coupe, because i need to replace the whole exaust system and i am wondering how much that will cost and the possibility of duels (after i put in a 350 of course)
Old Aug 8, 2008 | 08:43 PM
  #199
4RCEPWRD's Avatar
Car: 82Z28
Here's my setup I just had it done today. Hedman LT's reduced to 2.5" mandrel bent running to a couple Borlas.
Attached Thumbnails Third Gen Dual Exhaust Picture Collection-dualpic1.jpg   Third Gen Dual Exhaust Picture Collection-dualpic3.jpg
Old Aug 14, 2008 | 08:58 AM
  #200
89ta_jay's Avatar
Car: 89 Trans Am (under construction)
Engine: 350 tbi
Transmission: 700 r4
id like to hear a sound clip with the borlas
