long tubes or shorties? tell me info on both
Old May 4, 2008 | 10:04 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
Ok what I want to know is what do you find "better" for a car that is gonna be driven alot. its a weekend cruiser. It will get a cam eventually. The engine is a 1996 vortec 350 in 1992 z28. which would you go for? what are the benifeits and problems with both? they will run into a X or aftermarket Y pipe most likely.
Old May 5, 2008 | 04:43 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: long tubes or shorties? tell me info on both
Shorties-good-better than stock manifolds, easy to bolt up with y pipe that comes with it. good-good ground clearance for a DD Bad-not as good as longtubes.
Longtubes-good-Better performance. Bad-have to get a custom y pipe to fit 3" catbacks, sometimes can be a PITA to install.
Old May 5, 2008 | 09:37 AM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
Ultimately, Longtubes are the better headers... but ground clearance, installation, price, new exhaust, etc... can be a hassle.
But like 89formula said, shorties are definately better than the stock manifolds. Shorties will allow the car to breathe better and allow you to gain a little more power.
morrow
Jan 13, 2024 12:29 PM
87iroctheo
Dec 4, 2016 11:47 AM
Gunsbee
Sep 7, 2015 07:10 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
beast94
Aug 20, 2015 06:44 AM
