copper or aluminum gaskets?
Old May 18, 2008 | 03:13 AM
darkride86T/A's Avatar
From: North Carolina(but you'll never take the DC out of me!!!)
Car: '91 Formula,'02 Silverado,'15 200s
Engine: L98, LQ4, and 3.6 Pentastar
Transmission: 4L60/4L80E/9HP48
Axle/Gears: 2.73posi/3.73posi/3.73
I need to replace my header gaskets on my IROC. I've got an LB9 305 with square port heads and 1 5/8 inch round port Edelbrock TES headers. I've heard good things about both copper and aluminum gaskets. Which one seals the best, and is reuseable? Or do both seal well and are reuseable? A friend of mine swears by Percy's dead soft aluminum gaskets and another friend swears by copper gaskets. Both are similarly priced($35-40.00) and I don't mind spending the money on quality gaskets. Which ones do you guys recommend I go with?
Old May 18, 2008 | 12:39 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: copper or aluminum gaskets?
Yep, ither ones, they are reusable and worth the money, paper or other composite gaskets suck.
I have had my copper gaskets on 5 different motors and they still seal fins.
Old May 18, 2008 | 11:22 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
i notice that the aluminum gaskets r a lot thicker....Most aftermarket headers come with 3/4" long bolts, so does that mean that if u use the aluminum ones I would need to get 1" long bolts??...
and im with darkride86t/a......seems like the opinions between the 2 are split down the middle making it real hard to decide on which to use.
Old May 19, 2008 | 01:18 AM
I was at work today and another guy was telling me copper was the way to go, but the aluminum ones are also good. My local Autozone sells both and actually has Percy's dead soft aluminum gaskets in stock($34.99) The local Advanced Auto has Mr. Gasket .043 inch thick solid copper gaskets, with 1.63 inch round ports for $40.00
Old May 19, 2008 | 09:00 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
I am just indifferent, both last, i think if you had a slightly warped primary flange the aluminum would more than likely be the way to go.
Hotrodboba400
Dec 10, 2019 07:07 PM
gixxer92
May 18, 2017 11:20 AM
sreZ28
Oct 22, 2015 08:21 AM
bigjay89gta
Oct 15, 2015 08:04 AM
hdis2002
Sep 8, 2015 02:52 PM
