hooker 2210 problems!!
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
ok here is the problem my pass side header will not sit flush with the heads the bottom of the flange touches before the top can.. i can not see anywhere that it is touching the frame or anything had to grind the bracket for the control arm and move a brake line that was it. i have a thick alum gasket installed and the center tubes have a leak at the head. any help please would be apriciated
Car: 86 iroc
Engine: 383HSR
Re: hooker 2210 problems!!
what do yall think about these gaskets??
http://store.summitracing.com/partdetail.asp?autofilter=1∂=EAR%2D29D03BERL&N=700+4294925237+4294886211+4294921566+4294908254+115&autoview=sku
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
those gaskets will work, they fit the headers well enough.
sounds like the header is binding somewhere if its not sitting flush... or the worst case is that the flange is not angled right and assembled wrong.
The header may touch the kmember or the a-arm mount. those are the two places it was close to on my car. Also that brake line was close and touching in a spot or two, but i still got mine to line up well enough
i wont know if i have a leak or not until i start the car and run it for the first time
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
