spark plug removal with hooker super comp headers on 83 camaro
Old May 21, 2008 | 10:24 AM
monsooni's Avatar
Car: 83 camaro
Engine: 355 sbc 525hp
Transmission: 350 turbo built
Axle/Gears: 4.56
I have a new motor headers etc in a 83 camaro and i tried to tighten plugs on the heads and i cant get to a couple of them header is in the way to get socket on them. Does anyone know of a tool or different socket for this problem? THX TO ALL
Attached Thumbnails spark plug removal with hooker super comp headers on 83 camaro-img_0880.jpg   spark plug removal with hooker super comp headers on 83 camaro-img_0882.jpg   spark plug removal with hooker super comp headers on 83 camaro-img_0879.jpg
Old May 21, 2008 | 10:36 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Pretty common to use a short socket with a slot cut in one flat to get it past the insulator.
SLP sells one, I just took a socket and made it for myself.
Old May 21, 2008 | 10:44 AM
monsooni's Avatar
Car: 83 camaro
Axle/Gears: 4.56
Re: spark plug removal with hooker super comp headers on 83 camaro
THX Five7Kid
Old May 22, 2008 | 02:32 PM
five7kid's Avatar
Actually, the SLP socket is a slightly different concept - short socket, ratchet square machined out, use a hex wrench to turn. http://www.slponline.com/view_product.asp?P=30102
Sorry about the misinformation.
Old May 25, 2008 | 04:00 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
when i ran 2210's i did all my plugs with a 5/8 craftsman combination wrench.
i have some cheapies, and a mac..... craftsman had the best angle.
Old May 25, 2008 | 05:12 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Are you working on the side that you took the picture of? Those plugs look eally easy to get too. Try a 5/8" comb wrench. That should do the trick.
Old May 26, 2008 | 08:57 PM
RicksIroc86's Avatar
Car: 84 camaro z28
what motor is that?
Old May 26, 2008 | 09:19 PM
ssean92's Avatar
Car: sold
Damn that is a pretty car
Old May 26, 2008 | 11:07 PM
F_N_JUNK's Avatar
Car: 1991 Camaro
Engine: Morris 434 Single Turbo
Transmission: TH350
Axle/Gears: 9" Ford w/4.11's
5/8 wrench cut in half, works great!!
Old May 27, 2008 | 12:14 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Pass through ratchet works for me. Spark plug insulator passes through the ratchet head, just like a box end wrench. Found lots of other uses for it too.
http://www.gearwrench.com/catalog/xl...m/gearratchet/
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
db057
Aug 22, 2015 08:17 PM
3rdgenparts
Aug 8, 2015 07:09 PM
