camaro exhaust out behind door?
Old Jun 5, 2008 | 08:10 AM
smgseanmicheal's Avatar
Car: 86 z28
Engine: 305ish
Transmission: 700r4-kickdown cable
Axle/Gears: ill figure out when i pull it apart
i was just thinking about this and im curious if that would be possible its kinda but if i did it right id have a pretty unique camaro i think has anyone on here tried it but i wanna keep it street legal because im gonna start driving in a lil under a year and this is my project car cause it was either this or a buick regal thats all beat up but honestly would smoke my camaro or i was gettin an accord and i took the v8 cause i think ill have more fun with a camaro
Old Jun 5, 2008 | 08:49 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: camaro exhaust out behind door?
Its not really legal in most cases, check with your state. Exhaust must exit behind the passenger cabin. And since we have fastbacks with windows that go all the way back it needs to exit at the back of the car.
You probably won't encounter any problems with it though even if it isn't legal.
As far as uniqueness and originality, its over rated. Spend the money on headers or a 3" cat-back, you'll get a bigger kick out of that.
Old Jun 5, 2008 | 09:03 AM
Stephen's Avatar
Car: 87 GTA
Side exits are cosidered legal for cars like our, as exiting past or outide the passenger compartent. Hence the legality of sidepipes on any car.....or Cobras, Saleen/Roush (I forget which has it) the side exit exhaust.
Basically, as long as you exit it past the doors to the sides, and not under the car, you'll pass.
Andris's twin turbo Camaro here has side exits. I've seen several others, but that's the only oe that comes to mind.
Old Jun 5, 2008 | 03:56 PM
vette gator's Avatar
Car: 85 Z28
There's a car near me that has duals that come out near the back of the doors. The way the pipes are run, it looks like there might be as much as 3/4" clearance with the road. Doesn't look very practical to me in our town full of speed bumps, speed tables, speed whatevers, but if the owner is happy with it, it's cool with me.
Old Jun 5, 2008 | 06:50 PM
JohnC's Avatar
Car: 1988 IROC-Z
+1! Goin fast is better than lookin fast!
Old Jun 5, 2008 | 11:14 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
sort of like this?? its perfectly legal as long as it exits behind the door..
Old Jun 5, 2008 | 11:23 PM
Stephen's Avatar
Car: 87 GTA
Side exits are not only about looks.
The shorter, less turns in the pipes, gives less restriction. IE: More HP Not to mention, less piping =less weight=a faster car.
Old Jun 5, 2008 | 11:32 PM
Rva's Avatar
Rva
Car: 1984 z28 camaro
Old Jun 6, 2008 | 07:43 AM
Car: 86 z28
Engine: 305ish
nice but i was planning on running it out the body right above where u have them now i just gotta find a way to make room...
Old Jun 6, 2008 | 09:45 AM
Stephen's Avatar
Car: 87 GTA
I'm sure you were but....As long as your referring more to notching the body (ground fx) than actually INSIDE the body, you'll be legal.
The actual pipe exposed INSIDE wouldn't be legal. At least, not here in TX.
Old Jun 7, 2008 | 07:00 AM
Car: 86 z28
Engine: 305ish
i work at a drag strip and i was talking to a custom exhaust guy and he said that he could do it so on monday im gonna call him and see if running them out that way would be legal because i saw a saleen mustang with them that way last night
Old Jun 8, 2008 | 01:33 AM
84z350crate's Avatar
Car: 84 Z28
let me know where u go and how much it costs, I was thinkin of running z28 rectangle tips that way, plus I might live near u if u live near englishtown
Old Jun 9, 2008 | 09:25 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Is it just me, or does this car sit pretty high? Like, higher than stock?
Old Oct 4, 2008 | 12:41 AM
Luda92RS's Avatar
that does seem like alot of ground clearance, could be the angle though, it doenst look any higher then stock from the side
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
89lsc
Aug 14, 2015 04:58 PM
1nastygta
Aug 8, 2015 07:38 PM
