Hole where the TherMac riser used to be
Old Jun 5, 2008 | 02:29 PM
NoMoFoMoCo's Avatar
Been a forum lurker for a while, and can not thank you guys enough for the help you have given me... with out even knowing it.
After reading https://www.thirdgen.org/ultimatetbi to make sure there was nothing I was forgetting.... I am left with the querstion.....
Did you guys plug the huge hole in the exhaust manifold? I would think that would be a cause for the o2 sensor to wig out and cause some unwanted noise.
Old Jun 5, 2008 | 03:12 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Hole where the TherMac riser used to be
Welcome to TGO. There is no hole in the exhaust manifold. There is, however, a metal peice that clamps around the manifold (which allows the heat stove to be attached to the air box--I guess you'd call it radiated heat).
JamesC
Old Jun 5, 2008 | 03:32 PM
NoMoFoMoCo's Avatar
Ok, so the actual exhaust does not travel through that port, just the heat that the manifold creates? Well good deal on that part, that would then mean that the ticking I hear is coming from somewhere else. Is there a good way to know where the ticking is orriginating from?
Old Jun 5, 2008 | 03:36 PM
JamesC's Avatar
Correct on your first question. My old LG4 used to tick after shut down. I believe it's common. A search might provide more info on the subject.
JamesC
Old Jun 5, 2008 | 04:12 PM
NoMoFoMoCo's Avatar
Generally a search is the first place I go, and it gave a lot of options as to what could be ticking... Water pump, exhaust manifolds, Any of the pumps, heat shields, mufflers, etc. I was more asking how ya'll find out what is actually ticking? Is there a nifty lil tool or trick that is used?
Old Jun 5, 2008 | 05:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Get about a 2' long piece of heater hose, hold one end to your ear and the other end to various things you are thinking might be making the noise.
Exhaust manifold leak to the head is a pretty common cause of an annoying ticking noise.
Old Jun 6, 2008 | 09:58 AM
NoMoFoMoCo's Avatar
Sounds good. I will give that a try. Thank guys!
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
drumstixer
Sep 29, 2015 03:02 PM
