Hooker 2055's and Magnaflow catback
Car: 1999 Jeep Grand Cherokee
Engine: 4.7l PowerTech V8
Hey guys, i think i am going to order these two. However, what kind of power gain will i be looking at? How is that combo? any help would be appreciated.
Transmission: 4L80E/4L80E
As long as you get the catback for the '86-'90 TPI single cat application, it'll be fine.
Gains will depend upon what else you've done to the engine/car.
Re: Hooker 2055's and Magnaflow catback
OK, so i bought both things but now i have a question, since i wont be installing a new cat, im just going to put straight pipe there. should i still hook up the little tubes that are on the headers? or should i leave them? should i remove the smog pump? and this may be a nooby question, but the headers will come with gaskets and header bolts right? and do i spend the $$ to have a shop install the headers or could i do it? isnt there a big risk of breaking a manifold bolt in the head? thanks for your help and sorry for all the questions
Car: 80,81,85, trans am
Engine: 4.9,301turbo,350
Transmission: all auto
Axle/Gears: 308,342,308
anyone know what the hp gain will be on a stock tpi 350 with both of these? honest true numbers?
Car: !988 Camaro z28
Engine: Blueprint Engine Chevy 355ci
Transmission: 700 Corvette Servo
Axle/Gears: 4.11
I have this setup it works very nicely did it all myself, headers go in very nicely, and i noticed a very nice difference in hp and tourque
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
did you get the Y pipe that goes with the 2055 headers? if you didnt i would, fits great and saves hassle from having to build a Y pipe.
Axle/Gears: 4.11
Yes I did it worked great, even after my motor swap from a 305 to my 355
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
thats one of the main points i like about my 2055's, you can unhook the Y from the headers if you have to do any work and no gaskets involved.
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Only on TGO can you resurrect a 3 yr. old thread.
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
well i just ordered my magnaflow cat back to add to my hooker 2055 i bought used off someone here... hope i made the right choice....
however i think the 3" walker cat i have is ****. dont see how to install that without welding. gonna be a pain in the ***
no green
Jan 9, 2016 09:22 PM
